Benjamini and Hochberg False Discovery Rate
//********************************************************************* // statsBHFDR // // Implements Benjamini and Hochberg False Discovery Rate. Tolerates // more false positives but less false negatives. Least stringent // correction. // // Parameters: // w - input wave of p-values // // Optional Parameters: // ncol - column number of p-values if input wave w is a 2D matrix //********************************************************************* function statsBHFDR(w,[ncol]) //----------------------------------------------------------------- // parameters //----------------------------------------------------------------- wave w; variable ncol; //----------------------------------------------------------------- // variables //----------------------------------------------------------------- variable npnts,ndim; //----------------------------------------------------------------- // init variables //----------------------------------------------------------------- if(paramIsDefault(ncol)) ncol = 0; endif npnts = dimsize(w,0); ndim = dimsize(w,1); //----------------------------------------------------------------- // main function //----------------------------------------------------------------- // copy p-values out to new wave and make index wave make/free/n=(npnts) wpv,wpi; if(ndim) wpv[] = w[p][ncol]; else wpv[] = w[p]; endif // populate index wave wpi[] = p; // sort from highest to lowest sort/r wpv,wpv,wpi; // perform correction wpv[] = wpv[p]*(npnts/(npnts-p)); // restore original sorting sort wpi,wpv,wpi; // copy adjusted p-values to original wave if(ndim) w[][ncol] = wpv[p]; else w[] = wpv[p]; endif // set p-values greater than 1 to 1 w[] = w[p] > 1 ? 1 : w[p]; end
