Load wave details from IBW files directly from binary (without loading the data)
chozo
The following functions load the wave name, wave note or wave dimensions directly from the binary data of a given .ibw file without loading the file itself into Igor. The code should work for all file versions, but was not tested exhaustively and does not contain any error handling. Let me know if you find a file that does not work.
function/S readIBWname(string path) // reads wave name from .ibw file int fileID, version Open/Z/R fileID as path if (V_flag != 0) return "" endif FBinRead/B=3/F=2/U fileID, version int length = 20 + 12*(version>3) int offset = 6 + 8*(version==1) + 16*(version==2) + 20*(version==3) + (64 + 22)*(version>3) if (version > 5) FSetPos fileID, 56 FBinRead/B=3/F=2/U fileID, length FStatus fileID offset = V_logEOF-length endif string name = PadString("", length, char2num(" ")) FSetPos fileID, offset FBinRead fileID, name Close fileID return UnpadString(name,0) end // +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ function/S readIBWnotes(string path) // reads wave notes from .ibw file int fileID, version, chckSum = 0, wSize = 0, nSize = 0, fSize = 0 Open/Z/R fileID as path if (V_flag != 0) return "" endif FBinRead/B=3/F=2/U fileID, version if (version < 2) return "" endif if (version > 3) FBinRead/B=3/F=2/U fileID, chckSum // chckSum is only read to move position forward endif FBinRead/B=3/F=3/U fileID, wSize if (version > 3) FBinRead/B=3/F=3/U fileID, fSize endif FBinRead/B=3/F=3/U fileID, nSize if (version <= 3) FBinRead/B=3/F=3/U fileID, fSize endif int offset = wSize + fSize + 8*(version==1) + 16*(version==2) + 20*(version==3) + 64*(version>3) string notes = PadString("", nSize, char2num(" ")) FSetPos fileID, offset FBinRead fileID, notes Close fileID return notes end // +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ function/Wave readIBWdimensions(string path) // reads total no. of points and dimension size (if available) from .ibw file into free wave int fileID, version, points Open/Z/R fileID as path if (V_flag != 0) return $"" endif FBinRead/B=3/F=2/U fileID, version int offset = version > 3 ? 12 + 64 : 42 + 8*(version==1) + 16*(version==2) + 20*(version==3) Make/D/Free/N=(version > 3 ? 5 : 1) output // output is: [total points, p, q, r, s] or just [total points] for files with version < 5. FSetPos fileID, offset FBinRead/B=3/F=3/U fileID, points output[0] = points if (version > 3) offset = 68 + 64 Make/D/Free/N=(4) dims FSetPos fileID, offset FBinRead/B=3/F=3/U fileID, dims output[1,4] = dims[p-1] endif Close fileID return output end
