make VASP bands using EIGENVAL and OUTCAR
Yuan Fang
#pragma TextEncoding = "UTF-8" #pragma rtGlobals=3 // Use modern global access method and strict wave access. function bandplot(path1,fname1,path2,fname2) //normal bands plot string path1,fname1,path2,fname2 variable a,i,t,j,k variable fermilevel=7.0772 //fermilevel string str,fword,nkpts,nbnds Open/R a path1 + ":" + fname1 for(i=0;i<5;i++) FReadLine a, str endfor FReadLine a, str i=0 t=0 do fword=stringfromlist(i,str," ") if (stringmatch(fword,"")!=1) t=t+1 if(t==2) nkpts=fword endif if(t==3) nbnds=fword endif endif i=i+1 while(t<3) make/d/n=(str2num(nkpts),str2num(nbnds)) w for(i=0;i<str2num(nkpts);i++) FReadLine a, str FReadLine a, str for(j=0;j<str2num(nbnds);j++) FReadLine a, str k=0 t=0 do fword=stringfromlist(k,str," ") if (stringmatch(fword,"")!=1) t=t+1 if(t==2) w[i][j]=str2num(fword) endif endif k=k+1 while(t<2) endfor endfor for(i=0;i<str2num(nbnds);i++) make/d/n=(str2num(nkpts)) tmp tmp=w[p][i]-fermilevel duplicate tmp $"wave"+num2str(i) killwaves tmp endfor killwaves w close a Open/R a path2 + ":" + fname2 make/d/n=3 kold,knew make/d/n=(str2num(nkpts)) kpt do FReadLine a, str if(strlen(str)==0) break endif if(stringmatch(str,"*k-points in units of 2pi/SCALE*")==1) FReadLine a, str i=0 t=0 do fword=stringfromlist(i,str," ") if (stringmatch(fword,"")!=1) t=t+1 if(t==1) kold[0]=str2num(fword) elseif(t==2) kold[1]=str2num(fword) elseif(t==3) kold[2]=str2num(fword) endif endif i=i+1 while(t<3) kpt[0]=0 for(i=1;i<str2num(nkpts);i++) FReadLine a, str k=0 t=0 do fword=stringfromlist(k,str," ") if (stringmatch(fword,"")!=1) t=t+1 if(t==1) knew[0]=str2num(fword) elseif(t==2) knew[1]=str2num(fword) elseif(t==3) knew[2]=str2num(fword) endif endif k=k+1 while(t<3) if(mod(i,100)==0) kpt[i]=kpt[i-1] else kpt[i]=kpt[i-1]+sqrt((knew[0]-kold[0])^2+(knew[1]-kold[1])^2+(knew[2]-kold[2])^2) endif kold=knew endfor endif while(1) killwaves kold,knew close a for(i=0;i<str2num(nbnds);i++) if(i==0) display $"wave"+num2str(i) vs kpt else appendtograph $"wave"+num2str(i) vs kpt endif endfor end
December 22, 2019 at 05:25 am - Permalink
