make VASP bands using EIGENVAL and OUTCAR
#pragma TextEncoding = "UTF-8"
#pragma rtGlobals=3     // Use modern global access method and strict wave access.
function bandplot(path1,fname1,path2,fname2) //normal bands plot
    string path1,fname1,path2,fname2
    variable a,i,t,j,k
    variable fermilevel=7.0772  //fermilevel
    string str,fword,nkpts,nbnds
    Open/R a path1 + ":" + fname1
    for(i=0;i<5;i++)
         FReadLine a, str
     FReadLine a, str
     i=0
     t=0
     do
         fword=stringfromlist(i,str," ")
         if (stringmatch(fword,"")!=1)
            t=t+1
            if(t==2)
                nkpts=fword
            if(t==3)
                nbnds=fword
         i=i+1
     while(t<3)
     make/d/n=(str2num(nkpts),str2num(nbnds)) w
     for(i=0;i<str2num(nkpts);i++)
         FReadLine a, str
         FReadLine a, str
         for(j=0;j<str2num(nbnds);j++)
             FReadLine a, str
              k=0
              t=0
              do
                  fword=stringfromlist(k,str," ")
                      t=t+1
                      if(t==2)
                          w[i][j]=str2num(fword)
                  k=k+1
              while(t<2)
     for(i=0;i<str2num(nbnds);i++)
         make/d/n=(str2num(nkpts)) tmp
         tmp=w[p][i]-fermilevel
         duplicate tmp $"wave"+num2str(i)
         killwaves tmp
     killwaves w
     close a
     Open/R a path2 + ":" + fname2
     make/d/n=3 kold,knew
     make/d/n=(str2num(nkpts)) kpt
     do
         FReadLine a, str
         if(strlen(str)==0)
             break
         if(stringmatch(str,"*k-points in units of 2pi/SCALE*")==1)
             FReadLine a, str
             i=0
             t=0
             do
                     t=t+1
                     if(t==1)
                         kold[0]=str2num(fword)
                     elseif(t==2)
                         kold[1]=str2num(fword)
                     elseif(t==3)
                         kold[2]=str2num(fword)
                 i=i+1
             while(t<3)
             kpt[0]=0
             for(i=1;i<str2num(nkpts);i++)
                 FReadLine a, str
                 k=0
                 t=0
                 do
                         t=t+1
                         if(t==1)
                             knew[0]=str2num(fword)
                         elseif(t==2)
                             knew[1]=str2num(fword)
                         elseif(t==3)
                             knew[2]=str2num(fword)
                     k=k+1
                 while(t<3)
                 if(mod(i,100)==0)
                     kpt[i]=kpt[i-1]
                     kpt[i]=kpt[i-1]+sqrt((knew[0]-kold[0])^2+(knew[1]-kold[1])^2+(knew[2]-kold[2])^2)
                 kold=knew
     while(1)
     killwaves kold,knew
     close a
         if(i==0)
             display $"wave"+num2str(i) vs kpt
             appendtograph $"wave"+num2str(i) vs kpt
