wavestats not functioning
Dear Members,
I am working with NMR data (example is in the text file) and I want to know the xvalue for the max intensity for each resonances.
I tried the following command with wavestats:
wavestats/R=[3614,5461] intensity
to get the V_maxloc for the region between points 3614 and 5461 (also tried xcsr(a) and xcsr(b)), however I am getting the following output
V_npnts= 1848; V_numNaNs= 0; V_numINFs= 0; V_avg= 208319; V_Sum= 3.84974e+08; V_sdev= 36789.3; V_sem= 855.797; V_rms= 211541; V_adev= 33433.4; V_skew= 0.206091; V_kurt= -1.49705; V_minloc= 9030; V_maxloc= 8257; V_min= 160189; V_max= 265768; V_minRowLoc= 5369; V_maxRowLoc= 4596; V_startRow= 3614; V_endRow= 5461;
You can see the V_maxloc is out of the range that I have given and I could not get around this problem.
The main idea is to get the V_maxloc point and then locate the ppm corresponding to the value using
ppm[V_maxloc]
but got incorrect value.
I also tried the following commands
print wavemax(intensity, xcsr(a),xcsr(b)) value findlevel/P/R=[xcsr(a),xcsr(b)] intensity, value
However I get the error that the crossing cannot be found.
I would really appreciate and anyone can help me solve this issue.
Thank you,
Rubin.
Does your wave have non-default wave scaling? By default, V_[max|miin]loc are scaled values, not unscaled index values. However V_minRowLoc and V_maxRowLoc are always unscaled, and based on what you show those values are within the range you specified with /R.
August 7, 2019 at 11:29 am - Permalink
I think you want pcsr() to get point numbers instead of scaled X values.
August 14, 2019 at 10:29 am - Permalink
Sorry for the delay. Thank you for the suggestions I solved the issue by using pcsr() and also in the wavestats V_minRowLoc and V_maxRowLoc are the values that I have to take.
Thanks again.
Rubin.
August 28, 2019 at 09:39 am - Permalink
