Gizmo: Display of disk of an oblate spheroid
Hi Igorians,
I have found the disk around a spheroid can not be displayed in contrast to disks around a sphere.
I wish to create a gizmo plot of a hyperthetical planet with rings so I started with the “gizmoSphere” example. By typing a few commands like:
AppendToGizmo/D disk={1.5,1.7,100,5,0,360}
I was able to produce multiple rings surrounding the sphere as shown in the attached picture.
Then I change the sphere to an oblate spheroid by setting a=b=1.0 and c=0.8: (https://en.wikipedia.org/wiki/Spheroid#Oblate_spheroids)
Variable a=1.0, c=0.8
spheroidData[i][j][2]=sig*sqrt((1-(xx*xx+yy*yy)/a*a)*c*c)
•AppendToGizmo/D disk={1.5,1.7,100,5,0,360}
The spheroid and rings are still displayed fine, though igor auto scales z-axis from -0.6 to +0.6 so the spheroid looks like a sphere.
In order to better display the oblate spheroid, I manually set the Z-Direction Min Value and Max Value to -1 and +1 through “gizmo axis range”. Now the ring(s) can no longer be displayed. How to fix this?
igp 8.02,
Mac OS 10.13.6
Thank you.
zh
Rings surrounding a sphere
There are many ways to accomplish this.  For example, instead of setting the outer box add a scale operation to the display list right above the sphere object and have different scaling in the X, Y and Z components.  Draw the sphere AFTER you draw the rings.
