Using variables with #include
Hi everyone!
I am trying to load in procedures from certain paths using #include. As this routine should work on different computers with different users, it would be useful to work with variables to provide the file path, e.g.
string path="C:user_XY:procedurefiles:test_procedure"
#include path
However, include does not accept string variables as input.
Is there a way around this?
The way we intended #include to work is that you would create a shortcut from "C:user_XY:procedurefiles" and put the shortcut in the "User Procedures" folder of the "Igor Pro User Files" folder. Then you would simply use:
#include "test_procedure"
More simply, you can require that each use put his procedurefiles folder directly in the "Igor Pro User Files" folder and then use a simple #include.
For information on the "Igor Pro User Files" folder, execute:
DisplayHelpTopic "Special Folders"
