Using Grep to filter a text wave
Peeyush Khare
I have a text wave (txtwave) containing a list of formulas. The formulas have CHNO elements in them but some formulas have only CHO elements. I want to extract formulas (with their index numbers) that have only CHNO vs formulas that have only CHO. I have been using Grep/INDX/Q/E to extract things that contain something but I don't know whether there is a way to use Grep to exclude things that contain something while listing the remaining.
For example: I can do Grep/INDX/Q/E="N" txtwave and it will give me W_Index for all formulas containing CHNO.
However, how can I extract formulas that do not contain N?
Sincerely,
Peeyush
Here is a snippet from the Grep help:
and
March 24, 2022 at 06:20 am - Permalink
wow this is super cool! Thanks a lot, chozo! While we are at this, is there a way to set two parameters? So, if I want to say exclude everything that contains "N" and "O" both, is there a one-liner for this? I tried Grep/INDX/Q/E={"N","O",1} txtwave but this doesn't work..
Also, just for my understanding, when I write Grep/INDX/Q/E="N" txtwave, that's just the short form of saying Grep/INDX/Q/E={"N",0} txtwave. Is this correct? that there is no logical difference between the two statements
March 24, 2022 at 07:19 am - Permalink
In reply to wow this is super cool!… by Peeyush Khare
With grep the answer is pretty much always yes. My starting point is usually to search the web for 'regex' together with whatever I want to do. There are a lot of resources out there, regex testing engines and discussion boards filled with regex questions and answers. I strongly encourage taking a moment to look there as a first point of call when you have a regular expression question.
Note that you can use multiple regex flags with grep.
"N.*O|O.*N" is one way to say match both O and N.
March 24, 2022 at 08:42 am - Permalink
Thanks a lot, Tony! I didn't know about the regex pages. From here on, I'll check there first. Thanks for the syntax!
March 24, 2022 at 08:50 am - Permalink
In reply to Thanks a lot, Tony! I didn't… by Peeyush Khare
I have found the igor help to be a pretty thorough resource as well:
DisplayHelpTopic("Basic Regular Expressions")
March 24, 2022 at 10:30 am - Permalink
In reply to I have found the igor help… by KurtB
Thanks a lot for the tip, KurtB!
March 24, 2022 at 04:57 pm - Permalink
