Shortcut key for a procedure
Abdullah
I have this procedure file with a simple tasks that i use to analyse some of my data.
The thing is, sometimes i have more than a 100 oscillations (what i analyse) per file and i would like to add a short key for each procedure so once i place the cursor between the area of analysis i will be pressing a shortcut key instead of going to macros ....
Any help will be appreciated ....
attached below is my procedure
The /1, /2, /3, /4 numbers in there will append Command-1 through Command-4 (or Control-# for Windows) to the respective menu items. You can also require Shift and Option keys as well, such as /OS1 to require Command-Option-Shift-1.
January 26, 2013 at 07:57 am - Permalink
Excellent .....
Many thanks for your help, truly appreciated.
January 26, 2013 at 08:42 am - Permalink
