Scaled waves difference
I am trying to understand the way wave interpolation and differences in Igor Pro works.
I will try to be as short as possible.
I have two sets waves:
spectre1 = {10,12,14,16,19,33,98, 78, 56, 33, 21,12,10, 8} —> 14 pts.
temp1 = {10, 20 ,30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130,140} —> 14 pts.
spectre2 = {14,19,32,89,102,93,83, 78, 45, 30, 20,10} —> 12 pts.
temp2 = {11, 22 ,31, 41, 52, 63, 71, 82, 91, 103, 111, 122} —> 12 pts.
with different number of points.
Now I need to plot both spectra with its own temperature and make their difference. For this I first try to interpolate and scale the data using the following function :
Function InterpMe(Temp1, Temp2, spectre1,spectre2, InterpolatedSpectre1, InterpolatedSpectre2, PointsNumbers) Wave/D Temp1, Temp2 Wave/D spectre1, spectre2 String InterpolatedSpectre1 String InterpolatedSpectre2 Variable PointsNumbers Make/O/N=(PointsNumbers) $InterpolatedSpectre1 Make/O/N=(PointsNumbers) $InterpolatedSpectre2 Wave SpectreData1= $InterpolatedSpectre1 Wave SpectreData2= $InterpolatedSpectre2 WaveStats/Q Temp1 SetScale/I x V_min, V_max, SpectreData1 SpectreData1 = interp(x, Temp1, spectre1) WaveStats/Q Temp2 SetScale/I x V_min, V_max, SpectreData2 SpectreData2 = interp(x, Temp2, spectre2) End
Finally I end up with two waves, each scaled with the same number of points (let’s say 500). The only problem I have now is to make the “good” difference of this two waves.
T
I would suggest that the interpolation only be done over the range of points that is common to both "spectre" waves. Then the difference wave is created with this same x-scaling and the difference can be done using point values instead of scaled x values.
Your modified function is shown below. Along with a plot of the results. The difference plotted is Spectre1 - Spectre2.
You could interpolate/extrapolate both "spectre" waves over the range defined by the absolute min and max x values for both input waves, if you feel this is appropriate. That code is included, but commented out in the function below. The plot does not show this result.
November 22, 2016 at 06:56 am - Permalink
