Scaled waves difference
tutor
I am trying to understand the way wave interpolation and differences in Igor Pro works.
I will try to be as short as possible.
I have two sets waves:
spectre1 = {10,12,14,16,19,33,98, 78, 56, 33, 21,12,10, 8} —> 14 pts.
temp1 = {10, 20 ,30, 40, 50, 60, 70, 80, 90, 100, 110, 120, 130,140} —> 14 pts.
spectre2 = {14,19,32,89,102,93,83, 78, 45, 30, 20,10} —> 12 pts.
temp2 = {11, 22 ,31, 41, 52, 63, 71, 82, 91, 103, 111, 122} —> 12 pts.
with different number of points.
Now I need to plot both spectra with its own temperature and make their difference. For this I first try to interpolate and scale the data using the following function :
Function InterpMe(Temp1, Temp2, spectre1,spectre2, InterpolatedSpectre1, InterpolatedSpectre2, PointsNumbers)
Wave/D Temp1, Temp2
Wave/D spectre1, spectre2
String InterpolatedSpectre1
String InterpolatedSpectre2
Variable PointsNumbers
Make/O/N=(PointsNumbers) $InterpolatedSpectre1
Make/O/N=(PointsNumbers) $InterpolatedSpectre2
Wave SpectreData1= $InterpolatedSpectre1
Wave SpectreData2= $InterpolatedSpectre2
WaveStats/Q Temp1
SetScale/I x V_min, V_max, SpectreData1
SpectreData1 = interp(x, Temp1, spectre1)
WaveStats/Q Temp2
SetScale/I x V_min, V_max, SpectreData2
SpectreData2 = interp(x, Temp2, spectre2)
Wave/D Temp1, Temp2
WaveStats/Q Temp1
WaveStats/Q Temp2
Finally I end up with two waves, each scaled with the same number of points (let’s say 500). The only problem I have now is to make the “good” difference of this two waves.
T
I would suggest that the interpolation only be done over the range of points that is common to both "spectre" waves. Then the difference wave is created with this same x-scaling and the difference can be done using point values instead of scaled x values.
Your modified function is shown below. Along with a plot of the results. The difference plotted is Spectre1 - Spectre2.
You could interpolate/extrapolate both "spectre" waves over the range defined by the absolute min and max x values for both input waves, if you feel this is appropriate. That code is included, but commented out in the function below. The plot does not show this result.
Wave/D Temp1, Temp2
Make/O/N=(PointsNumbers) wOutput
WaveStats/Q Temp1
Variable min1 = V_min
Variable max1 = V_max
WaveStats/Q Temp2
Variable min2 = V_min
Variable max2 = V_max
Variable minfinal = max(min1, min2)
Variable maxfinal = min(max1, max2)
//Variable minfinal = min(min1, min2)
//Variable maxfinal = max(max1, max2)
SetScale/I x minfinal, maxfinal, SpectreData1
SetScale/I x minfinal, maxfinal, SpectreData2
SetScale/I x minfinal, maxfinal, wOutput
wOutput[] = SpectreData1[p] - SpectreData2[p]
November 22, 2016 at 06:56 am - Permalink
