Save Table Copy - Help
toledoeng
//for example savealltables ("_none_"," ") // "_none_" is used since the files are inside the current data folder Function savealltables(pathName, fileName) String pathName // Name of an Igor symbolic path. String fileName String tableName Variable index index = 0 do tableName = WinName(index, 2) if (strlen(tableName) == 0) break endif SaveTableCopy/P=$pathName/W=$tableName/T=1/A=1 as fileName index += 1 while(1) End
When I run this procedure it creates a blank txt file. What am I doing wrong? The only way I can get the results in the file is if I create a new table within Igor containing all of the results, then running the save procedure. However, if I have to create the table using Windows>NewTable I might as well save it out using File>SaveTableCopy. I am trying to streamline the steps as much as possible since I am dealing with large batches of files.
Any help would be appreciated.
I get the feeling that you want to save the contents of all of the waves in the current data folder to a file. For that you need to create a list of wave names and then save it using Save/J. /J means "delimited text". Here is a crack (untested) at what I think you want to do:
February 3, 2009 at 07:09 pm - Permalink
