Replacement of separation values / Save routine
I have a simple question, which actually bothers me a little bit. :-)
I am using IGOR since a long time (>7y), but this simple problem I did not get fixed.
I would like to import a tab-separated text file and just want to replace the separation charcter from tab to a semicolon. In the LoadWave routine I can choose the separator...in the Save routine its not possible (I think).
This replacement will be done automatically (called from Windows) and is needed to fulfill the actual program. I hope somebody has a smooth and easy idea to perform this. Anything is ready...I just need this easy part performed by IGOR ;-)
Many thanks and best wishes
Raik
Try the following code. It worked for my simple test. There is probably a better solution out there.
Jeff
May 5, 2011 at 10:57 am - Permalink
May 5, 2011 at 07:35 pm - Permalink
BR
Raik
May 9, 2011 at 12:40 am - Permalink
