Read and extract values of variables and waves' name using multithread function from mass # of waves
viralvector
Thanks for the help about extracting value of center of mass. I have tried to extract X axis peak position and center of mass using demo procedure - Thread-at-a-Time Demo
I am also interested in displaying each wave name from the variables. However, I have tried and failed.
I have learned that the I need to introduce string to extract wave name, but I don't know how to put the string with variables.
Please helps!
Here is the modified version to replace min and max value.
#pragma rtGlobals=3 // Use modern global access method. Menu "Macros" "Thread-at-a-Time Demo", ThreadAtATimeDemo() End // These control various troubleshooting items and other aspects of the demonstration Constant kNumDatasetsToProcess = 400 // Number of sample input waves to create and process Constant kSampleWaveNumPoints = 10000 // Number of points in each sample input wave Constant kPrintStartThreadMessage = 1 Constant kPrintGotThreadDFMessage = 1 Constant kSimulateVaryingComputationTime = 1 ThreadSafe Function ThreadWorker(wIn, waveIndex) WAVE wIn Variable waveIndex ////// //// String namewave = nameofwave(wIn) <---I introduce string here Wavestats/q wIn variable xPeak = V_maxloc Variable i,n=numpnts(wIn), massTimesX=0 for(i=0; i<n; i+=1) massTimesX += wIn[i]*pnt2x(wIn,i) endfor Variable totalMass=sum(wIn) Variable centerOfMass= massTimesX/totalMass // printf "Center of Mass: %g", centerofMass //return centerOfMass // This is used to simulate varying computation time if (kSimulateVaryingComputationTime > 0) Variable randomSecs = abs(enoise(kSimulateVaryingComputationTime)) Sleep/S randomSecs endif //Variable wMin = WaveMin(wIn) //Variable wMax = WaveMax(wIn) // Create data folder to return to calling thread NewDataFolder/S output // Create output variables // Variable/G gMin = wMin Variable/G gcenterOfMass =centerOfMass Variable/G gxPeak = xPeak // String/G gnamewave=namewave ( I tried to add this but it did not work) // This tells the calling thread which wave was processed Variable/G gWaveIndex = waveIndex // Send data back to main thread ThreadGroupPutDF 0, : return 0 // Success End Function ThreadAtATimeDemo() if (IgorVersion() < 6.23) Abort "This demo requires Igor Pro 6.23 or later." endif Variable t0 = StopMSTimer(-2) // Used to time the function DFREF originalDFR = GetDataFolderDFR() DFREF outputDFR = GetDataFolderDFR() Variable numDatasetsToProcess = kNumDatasetsToProcess Variable numDatasetsProcessed = 0 // Make output wave Make/O/D/N=(numDatasetsToProcess,3) outputDFR:results = NaN Wave results = outputDFR:results SetDimLabel 1,0,CenterOfMass,results SetDimLabel 1,1,Peak,results SetDimLabel 1,2,Name,results ///<----Third column I added for wavename // Create output table DoWindow /F OutputTable if (V_flag == 0) Edit /N=OutputTable /W=(466,49,906,652) results.ld endif // Look for sample data Variable numPointsInSampleData = kSampleWaveNumPoints // NewDataFolder /O :SampleData DFREF inputDFR = : String name Variable i for(i=0; i<numDatasetsToProcess; i+=1) sprintf name, "(%d)", i // wave0, wave1 // Make/O/D/N=(numPointsInSampleData) inputDFR:$name = gnoise(1) (disabled) SetDimLabel 0,i,$name,results endfor // Create threads Variable numThreads = ThreadProcessorCount Variable threadGroupID = ThreadGroupCreate(numThreads) SetDataFolder inputDFR // Needed for WaveRefIndexed // Dispatch threads and collect output Variable threadIndex Variable waveIndex = 0 do // Start any free threads do if (waveIndex >= numDatasetsToProcess) break // No more input data to dispatch to a thread endif // Find a free thread threadIndex = ThreadGroupWait(threadGroupID, -2) // Requires Igor Pro 6.23 threadIndex -= 1 // Because ThreadGroupWait returns threadIndex+1 if (threadIndex < 0) break // No free threads endif // Start thread Wave wIn = WaveRefIndexed("", waveIndex, 4) ThreadStart threadGroupID, threadIndex, ThreadWorker(wIn, waveIndex) if (kPrintStartThreadMessage) Printf "Started thread %d\r", threadIndex // For debugging only endif waveIndex += 1 while(1) // See if thread output is available DFREF dfr = ThreadGroupGetDFR(threadGroupID, 0) if (DataFolderRefStatus(dfr) != 0) // Process results NVAR gcenterOfMass = dfr:gcenterOfMass NVAR gxPeak = dfr:gxPeak NVAR gWaveIndex = dfr:gWaveIndex // NVAR gnamewave= dfr:$namewave <---- I tried this but it did not work because of string function I believe. results[gWaveIndex][0] = gcenterOfMass results[gWaveIndex][1] = gxPeak // results[gWaveIndex][2] = $namewave <-----It did not work // Update the output table DoUpdate // For debugging only if (kPrintGotThreadDFMessage) Printf "Got data for wave %d: CenterOfMass=%g, Peak=%g\r", gWaveIndex, gcenterOfMass, gxPeak endif numDatasetsProcessed += 1 // This is a free data folder that would be killed automatically by Igor. // Nonetheless we explicitly kill it here and now. KillDataFolder dfr endif while(numDatasetsProcessed < numDatasetsToProcess) Variable dummy = ThreadGroupRelease(threadGroupID) Variable t1 = StopMSTimer(-2) Variable elapsedTime = (t1 - t0) / 1E6 Printf "Finished ThreadAtATimeDemo in %.2f seconds.\r", elapsedTime SetDataFolder originalDFR End Function CleanupExperiment() // We call this to prepare the experiment for shipping DoWindow /K OutputTable // The table is recreated by the demo KillWaves/Z results // Output wave is recreated by the demo KillDataFolder /Z root:SampleData // Sample data is recreated by the demo End
Thank you very much!
needs to be:
January 17, 2014 at 09:19 am - Permalink
Thanks, I just learned the function of SVAR.
Here is what I added to:
In the function of
I introduced
string NameWave =NameofWave(wIn)
String/G gNameWave=NameWave
Then, in the function of
I added one column to the table
And introduced SVAR for wave name
But, I received error saying
results[gWaveIndex][2] = gNameWave
unknown/inappropriate name or symbol...
with my current knowledge, I don't know where is the error and I need your help.
Thank you!
Here is the code:
January 17, 2014 at 10:25 am - Permalink
Note that the results wave is numeric.
The string is not.
You can't assign a string to a number.
January 17, 2014 at 11:58 am - Permalink
Thank you.
Are there any ways to extract wave name as well as the two variables to the table using this algorithm? If so, you are welcome to make changes.
I guess the problem is the
gWaveIndex
? I noticed that gWaveIndex was assigned as variable. But I don't know how to convert it to string.Please bear in mind, I am new to IGOR and I try my best to understand programming syntax as a biologist. I need your advices and suggestions.
Thank you again.
January 17, 2014 at 12:47 pm - Permalink
Hello Jim,
Thank you for pointing out the error again. I have fixed the incomparability (text vs. numeric)
I got what I want with the minimal knowledge of programming.
Here is the code, just in case someone is interested in trimming it.
January 17, 2014 at 03:28 pm - Permalink
January 17, 2014 at 05:06 pm - Permalink
Hi jtigor,
Obtaining such values have made my life so much easier!!!
I see your point. I will try to change the output into string using num2str. If I got stuck in doing such changes, I will seek help here.
January 17, 2014 at 08:08 pm - Permalink
This can be a good technique. I think it's worth pointing out that when transmitting values via text you have to be *very* careful that you preserve the necessary precision of the numbers. A round-trip through num2str/str2num will truncate the values to 6 digits.
The num-string-num conversions are also slow. Since you are going to the trouble of writing threaded code, I presume speed is important to you.
As jtigor says, how you use the results is a crucial consideration.
January 20, 2014 at 09:37 am - Permalink
... becomes this ...
Your processing afterward is then a case of extracting the keyword=value set from gListInfo.
January 20, 2014 at 10:57 am - Permalink
