I am trying to use the command sort to invert the order of the values of a wave. I have a set of two waves, wavex and wavey and, while wavey goes in the correct direction, I would like to invert wavex. The wave contains decreasing negative points, going from -30 to -300 more or less. I would like to sort it as to have it going from -300 to -30. I tried to use Sort/R with various combinations of wavex and wavey but nothing changes...
Any suggestion??
V.
Do you actually need to sort or to invert the order of points in the wave? If you need to accomplish the latter, see the WaveTransform operation with the keyword flip.
June 20, 2018 at 08:19 am - Permalink
June 20, 2018 at 09:55 am - Permalink
June 21, 2018 at 02:08 am - Permalink
