Plotting a function f(x) in Igor with known parameter values
Dear All
Suppose I have a function f(x), f(x)= A*exp[-(B^2*x^2)/3].
And I know the values of the parameters A, B.
How do I, in Igor, plot this function f(x) from X=0 to x=infinity in order to determine the value of f(0)?
you can have a try with the Function Grapher in Analysis->Packages->Function Grapher.
bye, thomas
PS: Isn't it just f(x=0) = A*exp(0) = A?
Igor_user wrote:
...How do I, in Igor, plot this function f(x) from X=0 to x=infinity in order to determine the value of f(0)?
variable A=1, B=2
make/N=100 fx
setscale/I x 0, 10^6, "", fx
fx = A*exp(-(B*x)^2/3)
display fx
FWIW, setting the end point of the scale range on a data wave to infinity is rather problematic if not impossible to handle.
bye, thomas
I tried to make this expression as simple as possible just for the readers.
The actual equation involves some unknown constants before A and that have to be determined through an extrapolation of this function to f(0).
Then I would say you cut out the interesting part :)
You still haven't really given us sufficient detail. It sounds like it might be a job for curve fitting, which can find optimum values of unknown parameters if you have a data set that is modeled by the function.
Maybe you should provide some details about exactly what you're trying to do.
Ok,
The full function is expressed by this equation.
I(Q) = (N_p)*(V_p)^2*(D_sig)^2*G*exp[-(R_g)^2*(Q^2)/3]
Now, I have a data which is fitted by this function,
and I known G, (R_g), (D_sig) and I can work out (V_p) using (R_g).
But I have to determine (N_p) which requires the value of I(Q) at Q=0.
The problem is that my data doesn't cover Q=0. So, it requires some linear extrapolation at small Q to get the I(0) value.
How should I do that in Igor?
The attached experiment might help. The wave IQ has simulated data starting at Q=1. The fit is made to the function N_p*exp(-(R_g*Q)^2/3), with the fit range extending to the full range of the graph (0 to 10). The returned coefficients give N_p and R_g.
ExampleFit.pxp (51.44 KB)
