Panel with 'Enter' as default Ok button action.
Lars
I'm trying to build a small panel, that is supposed to resemble a dialog. Purpose is to enter a numeric value and store it in a global variable. The panel has for this purpose a SetVariable field and two buttons (OK and Cancel).
I'm handling the button actions via proc calls. Entering a value in the field and using the mouse to cancel or confirm the set value works fine.
What I miss is having the Return/Enter Buttons on the keyboard act as if clicking the corresponding button. I can't help but find no way to handle this?
With best regards, Lars Sölter
Function /S UI_NVarInput( varname, panelname ) : Panel
String varname
String panelname
String windowname
String usrdat = ""
String tmpvarname = varname+"_DNVI"
NVAR numvar = $(varname)
NVAR tmpnumvar = $(tmpvarname)
usrdat = ReplaceStringByKey( "NVARNAME", usrdat, varname, "=" )
if( NVAR_Exists( tmpnumvar ) == 0 )
Variable/G/D $(tmpvarname) = 0
if( NVAR_Exists( numvar ) == 1 )
tmpnumvar = numvar
usrdat = ReplaceStringByKey( "TMPNVARNAME", usrdat, tmpvarname, "=" )
PauseUpdate; Silent 1 // building window...
NewPanel /FLT=2 /K=1 /N=UI_NVarInput /W=(267,122,586,236) as panelname
windowname = S_name
SetDrawLayer UserBack
SetDrawEnv fname= "Segoe UI"
DrawText 15, 30, "Name"
SetDrawEnv fname= "Andale Mono"
DrawText 60, 30, varname
DrawText 15, 55, "Value"
SetVariable PanVar1 value=tmpnumvar, title=" ", pos={60,40}, size={240,10}, limits={-inf,inf,0}, font="Andale Mono"
Button ButtonOk, pos={140,78}, size={70,22}, userdata=usrdat, proc=UI_NVarInput_Ok, title="Ok"
Button ButtonOk,font="Segoe UI"
Button ButtonCancel, pos={230,78}, size={70,22}, font="Segoe UI", userdata=usrdat, proc=UI_NVarInput_Cancel, title="Cancel"
Button ButtonCancel,font="Segoe UI"
return windowname
Function UI_NVarInput_Ok( s ) : ButtonControl
STRUCT WMButtonAction &s
String varname
varname = StringByKey( "NVARNAME", GetUserData( s.win, s.ctrlName, "" ), "=" )
String tmpvarname
tmpvarname = StringByKey( "TMPNVARNAME", GetUserData( s.win, s.ctrlName, "" ), "=" )
switch( s.eventCode )
case 2: // mouse up
if( NVAR_Exists( tmpnumvar ) == 1 )
if( NVAR_Exists( numvar ) == 0 )
Variable/G/D $(varname) = 0
numvar = tmpnumvar
KillVariables /Z $tmpvarname
KillWindow $s.win
break
endswitch
Function UI_NVarInput_Cancel( s ) : ButtonControl
String tmpvarname
case 2: // mouse up
KillWindow $s.win
break
endswitch
String varname
String panelname
String windowname
String usrdat = ""
tmpnumvar = numvar
windowname = S_name
return windowname
String varname
String tmpvarname
case 2: // mouse up
numvar = tmpnumvar
KillWindow $s.win
break
endswitch
String tmpvarname
case 2: // mouse up
KillWindow $s.win
break
endswitch
STRUCT WMButtonAction &ba
switch( ba.eventCode )
case 2: // mouse up
// First, do whatever needs to be done, then close the panel
KillWindow Panel0
break
break
endswitch
Function DefaultButtonHook(s)
STRUCT WMWinHookStruct &s
Variable hookResult = 0
switch(s.eventCode)
case 11: // Keyboard
if (s.keycode == 11 || s.keycode == 13) // linefeed or carriage return
KillWindow panel0
hookResult = 1
break
endswitch
return hookResult // 0 if nothing done, else 1
Window panel0() : Panel
NewPanel /W=(150,50,450,250)
Button donebutton,pos={113,87},size={50,20},proc=DoneButtonProc,title="done"
Button donebutton,fColor=(0,0,65535)
SetWindow kwTopWin,hook(defaultbuttonhook)=DefaultButtonHook
EndMacro
First, run Panel0(). Then try clicking the button or pressing Enter.
Read about window hooks:
DisplayHelpTopic "Window Hook Functions"
My example uses a named hook function, which is preferred:
DisplayHelpTopic "Named Window Hook Functions"
March 13, 2013 at 12:52 pm - Permalink
switch(s.eventCode)
if (s.keycode == 30) // linefeed or carriage return
//increment the setvariable in your panel
hookResult = 1
elseif (s.keycode ==31)
//decrement the setvariable in your panel
hookResult = 1
break
endswitch
SetWindow kwTopWin,hook(defaultbuttonhook)=DefaultButtonHook, hook(setvariablehook) = SetVariableHook
EndMacro
I added the setvariable hook to John's Panel
March 13, 2013 at 02:36 pm - Permalink
Regards, Lars
March 14, 2013 at 07:05 am - Permalink
