NIDAQmx.XOP does not work in 32 bit version 7
Opening NIDAQmxFIFOProcs.ipf (FIFO scan) produce a window with a size that goes outside the visible screen, i.e. start control etc. cannot been seen and activated. Again a problem with the new handling of text ?
Found out it was a problem with setting the Windows default text size above 100%
Size of control panels in Igor 7 may change depending on lots of considerations. This was done to support high-resolution displays. If you run at 96 DPI (100% scaling), you should see little change. Running at 120 DPI (125% scaling) causes a switch in how we compute the scaling from pixels to points. You can read about this in our help:
DisplayHelpTopic "Control Panel Resolution on Windows"
In addition, you may need a newer version of the NIDAQmx.XOP for your NIDAQ Tools MX installation. There is an incompatibility between the shipping version of NIDAQ Tools MX and Igor 7. The fixed XOP will work with both Igor 7 32-bit and Igor 6. I am working on a 64-bit version.
