I got a new wave (wave2) which is created by wave0*0.1, it however doesn't have the same number of data point as wave0.
Anyone knows why?
The file is attached.
cheers[/quote]
When you made your initial waves you specified the number of data points as 212
Make/N=(212) wave3=0.0001
When you made wave2 use used the command
make wave2
This causes the default value of n=128 to be used.
My work habit is often to duplicate the wave in the wave browser and then rename as needed. This also copies the wave scaling which is often what I want and saves ne a step to explicitly set it.
make wave2
Andy[/quote]
I thought the command wave2=wave0*0.1 would create as many data point as wave0, didn't know it has a default number of data point 128 for every 'make wave' command used.
[quote=Igor_user]I thought the command wave2=wave0*0.1 would create as many data point as wave0, didn't know it has a default number of data point 128 for every 'make wave' command used.[/quote]
Go to the menu Help > Command Help. Go to the tab Command Help. Search for the Make command. Read the information. The end tells you the defaults.
Do the same for the Duplicate.
You made an assumption. Wave arithmetic is much more powerful and complicated than you suspect. Copy this command, paste it into Igor's command line and press Enter:
the command wave2=wave0*0.1 does NOT create wave2. Wave2 must already exist. Additionally, wave arithmetic operations do not change the number of data points within a wave.
You would either have to use make/n=(number of points) as mentioned by others, ensuring that the number of points is the same. OR you can use the Duplicate function. this will create a new wave with the same number of datapoints as the one you duplicate.
Anyone knows why?
cheers[/quote]
make wave2
May 14, 2014 at 09:48 pm - Permalink
make wave2
Andy[/quote]
May 14, 2014 at 11:02 pm - Permalink
May 15, 2014 at 04:52 am - Permalink
May 15, 2014 at 09:23 am - Permalink
May 15, 2014 at 10:11 am - Permalink
