Multivariate fitting with structure fit function in 64-bit Igor
billyblack
When using weight wave:
Error during curve fit: Weight data does not match Y data (length or number type)
When using destination wave:
Error during curve fit: Destination wave does not match Y wave (length or number type)
In both cases, the weight or destination wave are identical in size, type, scaling, etc. to the Y data wave. Works perfectly in 32-bit version of Igor.
Is there some subtlety I'm missing here for working in 64-bit mode? Or is this a bug in the 64-bit version?
Please post an Igor experiment containing everything I need to reproduce it. If it's big, and you can boil it down some, that would be a help.
December 10, 2013 at 01:58 pm - Permalink
December 10, 2013 at 03:15 pm - Permalink
http://www.wavemetrics.net/Downloads/latest/
Be sure to get the Igor64.exe download near the bottom of the page.
Thank you again for your report and the help in tracking down the problem.
December 10, 2013 at 05:01 pm - Permalink
