Multivariate fitting with structure fit function in 64-bit Igor
I am doing curve fitting of large data sets using a multivariate, all-at-once, structure fit function. Given the size of the data set, I would like to use the 64-bit version of Igor. I can use the basic form of FuncFitMD; however, when I implement either a destination wave or a weight wave I get the following errors.
When using weight wave:
Error during curve fit: Weight data does not match Y data (length or number type)
When using destination wave:
Error during curve fit: Destination wave does not match Y wave (length or number type)
In both cases, the weight or destination wave are identical in size, type, scaling, etc. to the Y data wave. Works perfectly in 32-bit version of Igor.
Is there some subtlety I'm missing here for working in 64-bit mode? Or is this a bug in the 64-bit version?
On the face of it, it sounds like a bug. That's quite a pile of less-used options: all-at-once, structure fit function, multivariate, Igor64...
Please post an Igor experiment containing everything I need to reproduce it. If it's big, and you can boil it down some, that would be a help.
Ok, here is a compact version of the experiment. You can look at the last two function calls - one was done in 32-bit and worked, the other was in 64-bit and gave the same error as I described. Let me know how it goes, and if you need anything else from me.
tryTCfitting_compact_no64.pxp (4.2 MB)
Thank you for providing the example of the problem- it was very helpful. You have, indeed, found a bug affecting only 64-bit builds. Tomorrow you can get a replacement of the Igor64.exe executable from the nightly build:
http://www.wavemetrics.net/Downloads/latest/
Be sure to get the Igor64.exe download near the bottom of the page.
Thank you again for your report and the help in tracking down the problem.
