Hello. Im an Igor Beginner and I've made a Macro to load delimited text and tell it to graph each columns. I also make a forward and a backward button so that i can scroll through the graph. But It give me error after i went through all my columns.
So here is my question, how can i tell my macro to stop and do nothing when column have no value? Or is there a way for me to tell the macro to find how many columns i have that contains numeric values and stop counting columns when it's blank?
Thank you very much.
[quote=thang]Hello. Im an Igor Beginner and I've made a Macro to load delimited text a...[/quote]
Your open1(...) and open2(...) functions might include an appropriate test of the values in either junk or tempwave.
if(tempwave[0]=NaN)
... (no data in this column, so do whatever is needed)endif
FWIW, the SpXZeigR routines found here already include a delimited text file loader and display control panel that you might find useful. The FTIR file loaders include a module that I believe works with the OOBase files (rather than the straight tab-delimited text files).
Also, the routines in LinkDisplay were designed for waves such as that loaded from an OceanOptics spectrometers where the first column is a "x-axis" that is to be linked to all other columns.
Finally, I've had to work extensively to load and display OceanOptics files before and would be glad to help off-line from this forum with your developments.
Let me know.
HTH
Let me know.
HTH
February 2, 2009 at 02:57 pm - Permalink
[/quote]
To test for equality you need to use ==, not =.
However, == does not work with NaN. You must use NumType:
As for the original question, I don't see where in your code you are trying to scroll through the graph.
To get information about traces in the graph use TraceNameList, TraceNameToWaveRef and WaveRefIndexed.
Also, you should not write macros but rather user-defined functions. For details, execute this:
DisplayHelpTopic "Programming Overview"
February 3, 2009 at 10:08 am - Permalink
Put this code in the open1 function just after loadwave
Put this code in the open2 function just before loadwave
That should stop the error messages.
February 6, 2009 at 05:16 pm - Permalink
