Interaction betweenTextbox with dynamically evaluated text and graph live mode
We are attempting to set the live mode of a graph to one (ex.
ModifyGraph/W=$graph live = 1) to keep the graph axes from updating with each change to the wave being displayed. A background function periodically toggles the live mode of the graph to update the axes. This works unless we also attempt to have a text box that displays dynamic text (From the manual "textStr can also contain the following escape code which inserts dynamically evaluated text:\{dynText }").
Is it expected that dynamic text would force the live mode of a graph back to zero?
Is the next best solution to manually scale the graph axes?
Thank you.
Not necessarily expected but it makes some sense from my modest understanding of what is going on internally. Dependencies, such as formed by := or \{dynText} are re-evaluated on an "update". An "update" updates everything - there is no selective update.
I would avoid dependencies, including \{dynText}, for the very reason that you have discovered - they can trigger at unpredictable times and cause unpredictable side-effects. Instead update the textbox yourself, using Textbox/C/N. You could do this in a window hook, in a button action procedure, or in a background task.
December 12, 2014 at 09:25 pm - Permalink
I have tried using a tag instead, and it doesn't seem to interact with the live mode in the same way a text box with dynamic text does, but it does require displaying the tagged wave which is why I tried to text box.
December 13, 2014 at 12:39 pm - Permalink
