how to modify the column name? I only find out the way to modify column cells.
pangeng
1, I want to align the name of the column in the way I want.
2, can I type super/sub-script in the cell of the table?
3, is there a way to modify the table in the unit of a cell but not changing whole column together?
many thanks!
Each column has an alignment that applies to the column name as well as the cells in the column.
Tables don't display formatted text - plain text only.
No.
It sounds like you are trying to use an Igor table as a formatted table. Igor tables are not suitable for that purpose.
One option is to create the formatted table in another program, such as a word processor.
In some relatively simple cases, it may be possible to write an Igor procedure that creates a formatted notebook with text formatted as you wish. You would have to use tabs to create columns.
If you create a sample notebook formatted as you with, you can use Notebook->Generate Commands to see the Notebook commands required to recreate the notebook. For details:
May 23, 2016 at 07:28 am - Permalink
