How to fix my Igor Pro Project - "Variable not declared"?
sabrina.thomae
I tried to create a new fit function in my project, but now Igor always tells me, that I have an error in this procedure - Function compilation error: variable not declared.
Here is the dialogue which I can see in the procedure window. I do not know how to fix it. Can someone help me?
Function Bessel(w,x) : FitFunc
Wave w
Variable x
//CurveFitDialog/ Equation:
//CurveFitDialog/ f(x) = exp(x/2)(a-1/a)
//CurveFitDialog/ x
//CurveFitDialog/ Coefficients 1
//CurveFitDialog/ w[0] = a
return exp((x/2)(w[0]-1/w[0]))
I would be really thankful for any help.
Regards,
Sabrina
Firstly, give your variable x another name. x, y, z, p, q, r all have special meanings in Igor. Don't use them as names for your own variables.
You also have to add the multiply symbol * between the two parentheses, and I assume both fit parameters, w[0] and w[1], should be in the equation. You have w[0] twice.
Maybe your equation should be something like this?
return exp((a/2)*(w[0]-1/w[1]))
February 22, 2020 at 06:55 am - Permalink
