How to apply an RGB color wave to a surface plot.
Hi All
I am having trouble with how to change the color of the surface plot of a 2D matrix wave (MxN).
Igor has preset colors for Surface plots, but I want to apply color waves from ColorWaveTables to Surface plots instead of preset colors.
The manual notes that the MxN 2D wave requires the MxNx4 color wave, but I can't find out how to make the three-column RGB color wave the type of wave to apply to Surface Plot.
I want to use spectral colors for Surface Plot, but what should I do?
Thank you
Hiroto
It seems like you are talking about Gizmo plots. In that case I have written a small function which creates a 4D color wave out of one of the preset tables:
Use as:
GizmoColorWave(yourInputData,colors=AcolotTableNameString)
At least this should give you an idea how to create your own color-table waves.
July 23, 2024 at 10:41 pm - Permalink
Gizmo supports the creation of color waves using the ModifyGizmo command with:
makeColorWave={srcWave, cTabName, isInverse }
Here is an example:
I hope this helps,
AG
July 24, 2024 at 01:48 pm - Permalink
Hi All
>>chozo
Thank you for sharing Igor macro.
Here's a question: What should I input into 'AcolotTableNameString' in this macro?
>>Igor
Thank you for the useful information.
This method converts CTablist colors into waves.
One more question, is there a way to make any Nx3 color wave apply to Gizmo Surface Plot?
I want to apply colors not bult-in Igor, which is not in CTablist, to Surface Plot, but I just can't figure out how to do it.
For example, could I apply the color wave from ColorTableWave to the Surface Plot?
Thank you
Hiroto
July 24, 2024 at 07:12 pm - Permalink
AColorTableNameString was meant to be a string containing a name of a supported color table, such as "Rainbow". But anyway, it seems you want to use your own color wave. For this, I have slightly modified my script:
Run as follows:
GizmoColorWave(yourPlottedData, YourColorWave)
The optional settings are:
The provided color wave must contain values from 0 to 65535.
July 24, 2024 at 08:50 pm - Permalink
Thank you!
That was exactly what I wanted to do.
I really appreciate your help.
July 26, 2024 at 01:49 am - Permalink
