If I press Shift and close a window, it saves without opening the dialog window. Is there a hot key to automatically not save a window and close it without opening the dialog window?
[quote=quoderatmac]If I press Shift and close a window, it saves without opening the dialog window. Is there a hot key to automatically not save a window and close it without opening the dialog window?[/quote]
It does not save the window in terms of creating a recreation macro, it rather hides the window, as far as I know. But if you press Alt (Mac) or Option (Windows) while closing a window, the window is killed with no dialog. See DisplayHelpTopic"Close Window Dialog"
Because I want to close a graph without saving 99% of the time, I have this running at startup:
ModifyBrowser slashK=1
(For some reason, this parameter is not documented for ModifyBrowser but still works)
That at least helps to get the desired behavior for graphs created from the data browser window.
DisplayHelpTopic "Close Window Dialog"A
February 22, 2012 at 09:18 am - Permalink
February 22, 2012 at 10:20 am - Permalink
ModifyBrowser slashK=1(For some reason, this parameter is not documented for ModifyBrowser but still works)
February 23, 2012 at 05:23 am - Permalink
