I am looking for a code that will help me filter the data I am dealing with. I need to apply the filter to approximately 600 files and would rather not have to do each individually. I am looking for a code that can perform a low pass filter with a cut off frequency of 2 and a sampling frequency of 2000 and order 2. Cascade (direct form II). Any help would be greatly appreciated.
For lack of further details in your query, I suggest you look at Igor's built in filter operation:
DisplayHelpTopic"FilterIIR"
There is a section devoted to Cascaded Bi-Quad Direct Form II Implementation. You will have to determine your filter coefficients, and write your own simple code to sequentially select the waves you need to filter.
[quote=s.r.chinn]
...write your own simple code to sequentially select the waves you need to filter.[/quote]
If you already have all of your data in Igor, one possibly simple approach would be to put all 600 1-D waves into a 2-D wave using "Concatenate" with each column representing a different data set. Then after setting up the FilterIIR filter, the filter could be called with the DIM=0 flag (i.e. FilterIIR/DIM=0) which applies the filter to each column. Then you'd need some short code to pull out each column ("q") into either a 1D wave or print to a file, depending on what you're trying to do.
August 9, 2016 at 09:57 am - Permalink
August 9, 2016 at 10:20 am - Permalink
