Fast way to raise a complex array to power n (element wise)
Sandbo
I am wondering if there is a way to speed up the operation:
SWaveN = Swave^n
I tried to look into FastOp and matrixOp, but it seems they do not have the ^ operation available (sorry if I missed).
Would there be another way?
June 4, 2018 at 10:21 am - Permalink
Thanks Igor for the prompt reply,
I tried the following code, where the old way was commented out.
They turned out slower, plus the CPU utilization stays around 15% on my i7-4790:
Did I apply it wrongly, or is there something I am missing?
June 4, 2018 at 11:06 am - Permalink
Not all MatrixOP functions have automatic multithreading so you need to be tricky in using it. How many points are in your wave?
June 4, 2018 at 12:49 pm - Permalink
Yes, I understand and I intended to do element by element multiplication of two arrays. Thanks for the note and I just updated the title.
The waves are 5e6 points each.
Also, I am on Igor 7 Version: 7.0.9.1 (Build 31885) (Nightly build downloaded earlier today).
June 4, 2018 at 01:33 pm - Permalink
Have you tried the Multithread keyword as in
Multithread momentWave=(ScWave^n)*(SWave^m)
?June 4, 2018 at 11:50 pm - Permalink
(1)
(2)
June 5, 2018 at 05:41 am - Permalink
It looks to me like you only have two source waves ScWave and SWave that you are raising to the power of 1, 2, 3, 4, 5 etc... If that is true couldn't you use the previous result for ScWave^n to calculate the next value ScWave^(n+1) simply as the old value times ScWave? Wouldn't that be faster, especially for large values of n?
It also looks like you are recalculating ScWave^n for each value of SWave^m. I would suggest to first calculate all values of ScWave^n then all values of SWave^m and then do the multiplication of the two.
June 5, 2018 at 05:35 am - Permalink
That's a good catch, I totally missed that and spent a lot of extra computation time. Thanks for pointing it out.
I should probably create a higher dimension wave and compute the ScWave^n and SWave^m recursively first, then call them in the ScWaveN*SWaveM loop.
June 5, 2018 at 08:29 am - Permalink
Thanks for the info, I didn't know I should do this. Now the CPU utilization goes up to 50% most of the time and they run much faster.
June 5, 2018 at 08:33 am - Permalink
