I'm trying to do cross correlations between two waves using the 'Correlate' command. I have a series of paired waves, and each pair may or may not be strongly correlated to the other. I want to get a result that says if the waves are identical, the max correlation is 1, if they have no correlation then the max correlation is 0. Autocorrelation scaling does not do this because it scales the center point to 1 no matter what. Any ideas?
Note: To compute a single-value correlation number use the StatsCorrelation function which returns the Pearson's correlation coefficient of two same-length waves.
StatsCorrelation does what you want.
July 17, 2017 at 11:56 pm - Permalink
