Constraints when using Global Fitting
yaohualiu
1. It causes problem when I set constraints such as: K1 < K2 < K3. K1, K2 and K3 are all fitting parameters.
2. The fitting program is easy to crash when too many constraints are set, which gives the following message, " Global Fit stopped for an unknown reason.". It runs well if I remove the constraints.
Any ideas on how to solve these issues?
thanks,
Yaohua
That is not a legal constraint expression. You need to break it into two expressions:
You need to read more about how constraints work in regular curve fitting. You can read the help files by executing this command on Igor's command line:
DisplayHelpTopic "Fitting with Constraints"
By "crash" I presume you mean that the fit ended with an error instead of a successful fit. It is easy to create a situation that is hard to solve when you use constraints. It is not essential, but is usually a good idea to make sure your initial guesses comply with the constraints.
If you are not using the latest update of Igor (6.22a) I highly recommend updating. Recently I added better error reporting for Global Fit.
May 27, 2011 at 08:46 am - Permalink
