Area Under Curve for 2D matrix of Peak Functions
n.black
I have a 2D matrix where each column is a Lorentzian curve (that I have made by extracting fit parameters from a curve fit procedure).
I want to calculate the area under the curve form y=0 for each column in the matrix. And put the result in a 1D wave.
NOTE I wanted my y intercept varied from +/-10 and I wanted to make it simple as the function only integrates from 0 and I wanted it all +ve hence the FalseDataMat which takes my original data and shifts it such that the y axis is 0.
Here's a snippit ofwhat I have so far.
Variable i Variable j for (j = 0; j < nCols; j += 1) for (i = 0; i < nRows; i += 1) FalseData[i][j]=Mat2D[i][j]-y0[j] endfor PeakArea[j]=areaXY(wnum,FalseAreaDataMat) endfor
I saw that the Area function only works on 1D waves. But I don't want to create a list of 1D waves...or do I have to extract.
I tried making a list of 1D waves and then killing them later but that didn't work very well.
Hopefully someone can help me!
N
November 13, 2015 at 10:53 am - Permalink
That did the trick and looks to be a very useful piece of code for me! I started reading the help topics around MatrixOp which is very useful.
Best,
N
PS what did you mean by suitable xwave? Correct dimensions?
November 15, 2015 at 09:18 am - Permalink
The area calculation requires that you have an X-wave that is common for all the columns in your matrix. If you do not have such a wave then use the Integrate operation but in that case you need to apply the appropriate scaling (MatrixOP waves have default wave scaling).
November 16, 2015 at 10:49 am - Permalink
Some Lorentz functions have analytical forms for their areas based on their peak parameters ...
http://magicplot.com/wiki/fit_equations
https://www.physicsforums.com/threads/area-under-the-following-curve-lo…
November 16, 2015 at 06:40 pm - Permalink
