Why is my function running twice?
Function/S returnsAWave(inputs) Variable inputs String returnNm = "thisNameDoesn'tMatter" // This is the wave I want Wave temp1 // This is the wave I'll actually generate for now ... // temp1 is being generated Duplicate/O temp1, $returnNm return returnNm End
So now, when I run
$(returnsAWave(inputs)), the result is the wave I need. Nifty, yes?Here's my problem: While I understand this may be a strange and not-very-Igory design pattern, it actually seems to make my function run twice. This runnable piece of code can verify that:
Function/S returnsAWave(i) Variable i print "This should only print once per function call" String returnNm = "thisNameDoesntMatter" // This is the wave I want Make/O/N=1 temp1 = {i} Duplicate/O temp1, $returnNm return returnNm End
In the command window:
• print returnsAWave(1) This should only print once per function call
• print $(returnsAWave(1)) This should only print once per function call This should only print once per function call thisNameDoesntMatter[0]= {1}
In the second case, the function is clearly running twice. But it feels as though if I run the function in either of these cases, the wave "thisNameDoesntMatter" should be generated once and only once. If it's happening twice, this is going to lead to some major efficiency issues (and I think it betrays my general confusion about how $ works, which is the main reason I'm asking). What's going on?
At least in IP 6.1 or later.
But you can't use that function in the command window as you would in the procedure window.
You would have to write
Now concerning your question. I can't reproduce that here. I always get an error message "expected assignment or operation".
For the $ vs literal have a look at
this is basically all you need to know about $ vs. literal.
July 21, 2014 at 02:11 pm - Permalink
[/quote]
Thanks for your response! Sorry, I found the error you were talking about and edited my code. (I forgot to put "print" in the the command window part :| )
I understand the job of $ and your post did a great job of naming its many uses. None of them seem to explain this issue in particular though... it's a strange edge case.
July 21, 2014 at 02:38 pm - Permalink
Anyone who saw my first answer- please forget it :)
July 21, 2014 at 04:49 pm - Permalink
Once when interpreting the command line, and again for the Print command.
[/quote]
Thanks, I thought it might be something like that... Is there a concise way to explain why this happens? I'm continually more confused about how (and where) $ works.
July 22, 2014 at 02:46 pm - Permalink
No.
[quote]I'm continually more confused about how (and where) $ works.[/quote]
You and many others, but you have taken it to a new level :)
In general you would use $ in a user function; using it on the command line in interpreted commands is not really expected. So in the function
it works as you expect.
And Thomas Braun's advice is good- make ReturnsAWave() return a wave reference rather than a string.
July 23, 2014 at 09:56 am - Permalink
