extracting open and close times for a valve from a continuous sequence
jschroed
Here is my setup:
I have an instrument that whose inlet is controlled by a valve. This valve opens at irregular intervals, but usually about once every ten minutes. Once open, the valve then closes after a certain interior pressure is reached - so the "valve open time" is also not regular. The raw data feed that we get is recorded every second, and the valve status is indicated by a 0 or a 1, where 0 is closed and 1 is open. What I'd like to do is to extract all of the times where the valve is open.
basically, I have a data set that is all "0"'s, with randomly sized sets of "1"'s scattered throughout. I'd like to pick out time for the first and last "1" in each set, and I'm not sure how to do that. I'd appreciate any help!
July 19, 2014 at 08:06 pm - Permalink
FindLevels should do what you want. From help...
This will find all locations where a level of 0.5 was crossed in the wave wValveWave.
FindLevels /Edge=0 wValveWave, 0.5
The location of the crossing will be halfway between the delta x of your wave scaling. If needed, you can add half delta x to the start of the valve on time and subtract the same from the end of the time to place the start/stop times at the "1" value. Also watch out for the possibility that the data wave begins or ends with a value of "1".
July 19, 2014 at 08:29 pm - Permalink
July 20, 2014 at 08:48 am - Permalink
/Edge=1 finds crossings where Y is increasing
/Edge=2 finds crossings whee Y is decreasing.
This is explained in the help file.
I find the Help Browser (Help Menu > Command Help) to be a most wonderful source of info.
Also if you set the crossing level to something like, say, 0.9. Then x value reported by FindLevels will be much closer to x value where y = 1 at the crossing. If your x values are integers, then round will return the exact x value that you seek.
July 20, 2014 at 09:06 am - Permalink
July 20, 2014 at 09:27 am - Permalink
