Include data in a user-defined fitting function
mjd
The intensity is a function of frequency, with some fitting parameters. I also have data for refractive index as a function of frequency, and would like this data to be included in the fitting function (so the fitting function has independent variable frequency, dependent variable intensity, and includes a parameter that depends on frequency).
I have tried including refractive index as another independent variable, but unsurprisingly this doesn't work as it depends on frequency.
Any assistance much appreciated,
July 9, 2014 at 03:29 am - Permalink
I would like to use another wave for the refractive index.
Originally I used the curve fitting GUI to input my functions, ignoring the refractive index entirely. This gave the procedure window below.
What I want to do is to insert the data for the refractive index wave for each value of frequency into the expression
(k*(a*frequency)^2*exp(-(b*frequency)) (this is a simplified version)
to give something like
k*refractive_wave*(a*frequency)^2*exp(-(b*frequency))
I have attached the experiment file as well.
Thanks again
____________________________________________________
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
Function simple_example(w,frequency) : FitFunc
Wave w
Variable frequency
//CurveFitDialog/ Equation:
//CurveFitDialog/ f(frequency) = k*(a*frequency)^2*exp(-(b*frequency))
//CurveFitDialog/ frequency
//CurveFitDialog/ Coefficients 3
//CurveFitDialog/ w[0] = k
//CurveFitDialog/ w[1] = a
//CurveFitDialog/ w[2] = b
return w[0]*(w[1]*frequency)^2*exp(-(w[2]*frequency))
July 9, 2014 at 06:03 am - Permalink
But what I have written here is certainly wrong, because I don't know how the values in the wave should be indexed. The way I have written it, using parentheses, assumes that the wave has the X scaling set so that the values can be looked up directly using the input frequency. The value returned by
refractive_index(frequency)
will be interpolated between the actual values if the frequency falls between values that exist in your wave.If this is puzzling to you, please read:
DisplayHelpTopic "Waves"
and especially
July 9, 2014 at 09:31 am - Permalink
