extracting data from a wave to make a new wave
appaloosahotdog
Here are the functions I'm writing in total. The first loads peak areas from several chromatograms and the second loads the concentrations used for instrument calibration purposes. The idea is to match the correct peak areas with concentration values for each ion by wave name and ultimately generate linear calibration curves for them all - of which i am only interested in the fitted curve's equation.
Thanks in advance for any help.
#pragma rtGlobals=3 // Use modern global access method and strict wave access.
Function load(pathName, filePath)
string pathName, filePath
if (strlen(filePath) == 0)
Open/D/R/P=$pathName refNum as filePath
if (strlen(S_fileName) == 0)
return -1
filePath = S_fileName
LoadWave/J/D/O/K=0/A/B="N='_skip_'; N='_skip_'; N='_skip_'; N='Sig1';"/P=$pathName filePath
wave/T Sig1
make/o/N=(numPnts(Sig1)) PeakArea
PeakArea = str2num(Sig1[p])
MatrixOp/o PeakArea = replace(PeakArea, NaN, 0)
edit PeakArea
variable index
string name
make/o/N=10 tempwave
for(index = 0; index<12; index+=1)
name = "PA" + num2str(index)
extract/o PeakArea, tempwave, p>=14*index && p<=14*index + 13
duplicate tempwave, $name
killwaves tempwave
make/o/N=10 PA0, PA1, PA2, PA3, PA4, PA5, PA6, PA7, PA8, PA9, PA10, PA11
appendtotable PA0, PA1, PA2, PA3, PA4, PA5, PA6, PA7, PA8, PA9, PA10, PA11
load2("","")
Function load2(pathName, filePath)
Open/D/R/P=$pathName refNumas filePath
return -1
LoadWave/J/D/O/K=1/A/B="N='Concentration';"/P=$pathName filePath
wave Concentration
appendtotable Concentration
variable index
string name
for(index=0; index<12; index+=1)
name = "Conc" + num2str(index)
extract/o Concentration, tempwave, p>=10*index && p<= 10*index + 9
appendtotable $name
killwaves tempwave
return -1
wave/T Sig1
edit PeakArea
variable index
string name
killwaves tempwave
load2("","")
return -1
wave Concentration
variable index
string name
appendtotable $name
killwaves tempwave
Also, bracket your code with <igor> and </igor> tags.
June 30, 2014 at 01:10 pm - Permalink
June 30, 2014 at 03:33 pm - Permalink
1 water n.a. n.a. 2 water n.a. n.a. 3 A1 4.794 0.0080 4 A2 4.797 0.0308 5 A3 4.800 0.0620 6 A4 4.800 0.1190 7 A5 4.800 0.1454 8 A6 4.800 0.5873 9 A7 4.797 1.2083 10 A8 4.797 2.5246 11 snow 4.800 0.3649 12 snow 4.800 0.3662 13 water n.a. n.a. 14 water n.a. n.a. 1 water n.a. n.a. 2 water n.a. n.a. etc...
Loading the wave as text is reasonable given the unusual file formatting.
Loading only column 4 seems to work fine:
You then replace the n.a. values with 0 (which is a little questionable).
These questions:
do not make any sense to me. I may need more coffee.
June 30, 2014 at 04:07 pm - Permalink
however, while playing with the data in a table, i realized that some of the values were not being loaded. for example,
10 C8 9.940 15.7039
In that line of data, the fourth column remains blank when loaded by my program.
Since i can't be sure if the spacing in the txt files will be uniform and can't double check for errors when the deluge of data arrives, this problem seems to be a serious concern.
I did some backtracking by loading the waves in a different manner, and found that loading the txt into one wave works. all the data is there.
That's why I'm asking how to pull a wave from a wave. Does that make my problem clearer?
June 30, 2014 at 09:25 pm - Permalink
If you are asking how to extract the 4th column from a 2D text wave into a 1-column ("1-D") numeric wave, then that I can answer:
Make/O/N=(20,4)/T tw= num2str(enoise(1))
Wave fourthColumn = ExtractTextColumnAsNumericWave(tw, 3, "FourthColumnWave")
Function/WAVE ExtractTextColumnAsNumericWave(twoDWave, column, usingName)
WAVE/T twoDWave
Variable column
String usingName
Variable rows= DimSize(twoDWave,0)
Make/O/N=(rows) $usingName/WAVE=w
w= str2num(twoDWave[p][column]) // this is a "Waveform Assignment" statement
return w
June 30, 2014 at 11:21 pm - Permalink
The 'problem' with your data is that some lines contain a fourth tab character, making these lines essentially 5 columns in width. The loading command interprets the data as four columns (probably concluding from the structure of the first line) and then never looks again and just loads the "emptiness" after the 1st tab character, ignoring the data which comes afterwards. That's why loading into one column works (I guess you use something like
LoadWave/J/O/K=2/A/V={"", "",0,0}
). If you come that far, all that's left to do is to get rid of the additional tab character and reinterpret the data, like this:wave/T w
w = ReplaceString("\t\t",w[p], "\t") // kill 2nd tab
make/d/o/n=(DimSize(w,0)) Fourthcolumn
Fourthcolumn = str2num(StringFromList(3, w[p], "\t")) // get the data
Hope that helps.
July 1, 2014 at 03:18 am - Permalink
variable refnum
open/R refnum //modify to take path if you don't want the dialog pop-up
string str
variable i=0
make/t/o/n=(400000) wave0 //make wave extra large to start to ensure enough entries.
//alternative is to check number of rows first and make the wave to the proper size
do
freadline refnum, str
wave0[i]= stringfromlist(itemsinlist(str, "\t")-1, str, "\t") //extract last entry for row i
fstatus refnum
i+=1
while (v_filepos<v_logeof) //stop when we reach end of file
close refnum
redimension/n=(i) wave0 //delete extra entries from initially large array
//add code here to change "n.a" from text file to NaN
//modify as needed to accept file path and name wave properly
July 1, 2014 at 07:47 am - Permalink
I've succeeded in loading the txt file into a single wave with this code:
wave wave0
But neither of the functions you've suggested extract the fourth column of data from wave0.
attached is the full code using jim's suggestion:
return -1
LoadWave/J/D/E=1/K=2/A/V={""," $",0,0}/L={0,0,0,0,1}/P=$pathName filePath
wave wave0
ExtractTextColumnAsNumericWave(wave0, 4, "Sig1")
wave/T Sig1
edit PeakArea
variable index
string name
killwaves tempwave
load2("","")
return -1
wave Concentration
variable index
string name
appendtotable $name
killwaves tempwave
WAVE/T twoDWave
Variable column
String usingName
return w
July 1, 2014 at 09:02 am - Permalink
return -1
wave wave0
Extract4thColumn(wave0)
wave/T Sig1
edit PeakArea
variable index
string name
killwaves tempwave
load2("","")
return -1
wave Concentration
variable index
string name
appendtotable $name
killwaves tempwave
Function Extract4thColumn(w)
wave/T w
make/d/o/n=(DimSize(w,0)) Sig1
Sig1 = str2num(StringFromList(3, w[p], "\t"))
July 1, 2014 at 09:05 am - Permalink
String columnInfo = "N='_skip_';N='_skip_';N='_skip_';N='Sig1',T=4;N='_skip_';"
LoadWave/J/D/O/A/B=columnInfo /P=$pathName filePath
I had to remove the /K flag and add ",T=4" to the /B flag.
I also added an extra "skip" at the end so LoadWave will ignore the extra tabs found on some lines.
This gives you a numeric output wave.
The "n.a" entries load as NaN. If you want to replace NaN with zero, add this:
Wave w = $name // Wave reference
w = NumType(w)==2 ? 0:w // Replace NaN with zero
July 1, 2014 at 09:38 am - Permalink
July 1, 2014 at 10:24 am - Permalink
That's because that line of text in the file has two tabs before column 3 instead of 1. I thought the extra tabs were all at the end of a given line.
In this case I would create a filtered version of the file by replacing tab-tab with tab. For an example of creating a filtered file and loading the filtered file, see:
http://www.igorexchange.com/node/1221
Your FixText routine would look like this:
// Returns cleaned up version of text by replacing <tab><tab> with <tab>
static Function/S FixText(textIn)
String textIn
String textOut = ReplaceString("\t\t", textIn, "\t")
return textOut
While you are at it you might as well remove the stray tabs at the end of some lines:
// Returns cleaned up version of text by replacing <tab><tab> with <tab>.
// Also removes a single stray tab at the end of any line.
String textIn
// Replace tab-tab with tab
// Get rid of stray tab at the end of a line
textOut = ReplaceString("\t\r", textOut, "\r") // Handles tab-CR
textOut = ReplaceString("\t\n", textOut, "\n") // Handles tab-LF
return textOut
July 1, 2014 at 10:36 am - Permalink
I took your data and used the loading command, then applied my function and it is working just fine. I guess there is something not working with the implementation. For example, here:
wave/T wave0 // you loaded a text wave, so you need the /T flag here. Also my function eats only text waves
wave Sig1 // the output is a numerical wave, so no need for a /T flag here
//make/o/N=(numPnts(Sig1)) PeakArea // you don't need this part, ...
//PeakArea = str2num(Sig1[p]) //... because it was already done in the function Extract4thColumn
// (you can work with Sig1 directly from here on)
Note also that the 'n.a.' rows turn out as NaNs in the numerical wave obviously. You can convert these later to zeros if you wish.
July 1, 2014 at 09:42 pm - Permalink
July 2, 2014 at 09:51 am - Permalink
