Index Out Of Range and Logic in Wave arithmatic
So I've got a nice little image, and that image has some NaN values that I need to eliminate to be able to do things like ffts, sums, ect
I've traditionally done this kind of thing in a nested for-loop, where I'll check each element index by index, and if I find a NaN, I'll replace that with a neighboring value (our imaging resolution is lower than our pixel size).
This is slow. So I'm trying to replace it with this line of code:
TheTrap[][] = (TheTrap(p)(q)!=NaN)*TheTrap(p)(q) +(TheTrap(p)(q)==NaN && p>0)*TheTrap(p-1)(q) +(TheTrap(p)(q)==NaN && p==0)*TheTrap(p+1)(q)
The first bit returns the original image if it has a finite value. The second bit replaces any NaNs found with the value of the pixel to the left if there exists a pixel to the left. And the final bit replaces any NaNs found on the leftmost part of the image with the value of the pixel immediately to the right.
What I get when I run is an "index is out of range" message, because in the second bit the program is ostensibly trying to multiply 0*TheTrap(-1)(q). Is there a way to get around this without resorting to a for loop?
1) Comparing with NaN always returns false, per IEEE standard. You need (numtype(TheTrap[p][q])!=0) or (numtype(TheTrap[p][q]) == 0) instead.
2) How about MatrixFilter NaNZapMedian?
3) Use a subrange to limit the left-hand side:
Variable rows = DimSize(TheTrap, 0)
Variable cols = DimSize(TheTrap, 1)
TheTrap[1,rows-1][1,cols-1] = ...
TheTrap[0][1,cols-1] = ...
etc.
The following function does what you want without generating an out-of-range error. However, you might want to look into the MatrixFilter solution as suggested.
Function ReplaceNans(w)
    Wave w
    w[][] = numtype(w[p][q])==0 ? w[p][q] : w[p-1+2*(p==0)][q]
Also note that when the leftmost (p=0) AND the adjacent pixel to the right (p+1) contain NaNs the function is unable to overwrite these.
[quote]Also note that when the leftmost (p=0) AND the adjacent pixel to the right (p+1) contain NaNs the function is unable to overwrite these.[/quote]
And MatrixFilter documentation claims that NaNZapMedian "automatically cycles through matrix until all NaNs are gone".
Thank you all very much! Pretty much everything every one of you said was new to me.
