creating wave
nstanell
Nathan
Function MatrixChoiceX() string chosenxmatrix Prompt chosenxmatrix, "Name of the X Matrix: ",popup,wavelist("*",";","DIMS:1") Doprompt "Choose the wave:", chosenxmatrix wave resultx = $chosenxmatrix End Function MatrixChoiceY() string chosenymatrix Prompt chosenymatrix, "Name of the Y Matrix: ",popup,wavelist("*",";","DIMS:1") Doprompt "Choose the wave:", chosenymatrix wave resulty = $chosenymatrix End Function trapezoidalpeakarea(a,b) : ButtonControl variable a,b //inputted bounds given by the user wave xdata = MatrixChoiceX() wave y data = MatrixChoiceY() Prompt a, "Lower bound of the peak:" Prompt b, "Upper bound of the peak:" DoPrompt "Select the waves and set the upper and lower bounds of peak region", a,b variable result = 0 variable i for (i=a; i <= (b-1); i += 1) result = result + (xdata[i+1]-xdata[(i)])*((ydata[i]+ydata[(i+1)])/2) endfor return result End
June 5, 2014 at 09:25 am - Permalink
You also might want to take a look at AreaXYBetweenCursors:
June 5, 2014 at 09:28 am - Permalink
June 5, 2014 at 11:46 am - Permalink
Not really; you'd have to convert to using a panel and wave widget selector controls.
See File->Examples->Programming->WaveSelectorWidgetExample.pxp
[Edit: okay, actually you *could* write a new string function for the wave prompts that iterated all the waves in all data folders and returns a list of the full paths to those waves. The result would be somewhat unwieldy if you have a complicated datafolder hierarchy.]
June 5, 2014 at 03:06 pm - Permalink
