Quicktime requirements and .avi format
I purchased Igor and am trying a fresh install of the latest version, and am running into trouble.
First up is a 25,000kb avi I would like to import. I used to work with TIFF a lot and that was easy enough: data/load waves/load image etc.. I can see now that .avi is not directly supported, or is there another method I am missing for this task? I am looking at the PlayMovie and PlayMovieAction commands for example, and it seems I can script something to capture my avi frame by frame into wave form, but this seems to be a very long way around solution.
If I try to load it as a tiff regardless, I then get an error message that Quicktime is not installed (on my PC). So you use Quicktime to deal with unrecognized formats from what I can see in the documentation.. Is there any other use or requirements of this program? Can I can avoid it installing it completely?
Ian
