I call Cursor/M to modify some properties of the cursor without changing it's position (which is also convenient for working with both traces and images, as I don't have to discern between Cursor/I and Cursor). But I noticed the "cursormoved" event in a window hook gets triggered for every cursor (i.e., A,B,C,D ...) on there, even if I only modify just one of them with the command of course. Is this a bug or a feature? Calling Cursor without the /M flag doesn't do this. If the explanation is not clear, I can try to construct an minimal example some time later. I am running Igor 6.34 on Windows 7.
Thanks for the example. Thats really odd as I see multiple unexpected things here:
What is Cursor/M A supposed to do? You are not changing anything with this call.
The /M flag generates events for all three cursors and not only for the given cursor.
Even if the event should have been named "cursorchanged" instead of "cursormoved" the /M flag should not generate events for other cursors or if you haven't changed anything.
Also, there is absolutely no method of determining where the call comes from, as all values stay the same (even the time (ticks); try printing the whole structure and see what I mean).
Regarding 1): Cursor/M could be used to trigger an update in the hook function, precisely without changing the current state.
A short code example would be nice indeed.
May 19, 2014 at 01:10 pm - Permalink
Executing, for example,
Cursor/M A
after building the window will printA
B
C
May 19, 2014 at 05:46 pm - Permalink
Cursor/M A
supposed to do? You are not changing anything with this call.Even if the event should have been named "cursorchanged" instead of "cursormoved" the /M flag should not generate events for other cursors or if you haven't changed anything.
Sounds like a bug for me.
Thomas
May 20, 2014 at 12:30 am - Permalink
May 20, 2014 at 03:16 am - Permalink
The running of hook functions is simply a byproduct of the update. It is not designed to trigger a specific cursor hook.
We could add some extra code to update only one cursor - probably would not break anything but you never know....
Larry Hutchinson
WaveMetrics
support@WaveMetrics.com
May 20, 2014 at 04:41 pm - Permalink
