Use 'CreateBrowser <prompt>=<value>' without changing the current position and size of the "Data Browser" window?
When I use the 'CreateBrowser =' command, I like to use the current properties of the "Data Browser", such as the position and the size etc. Is there an option I can use?
Without any option, it will use the default setting.
Yaohua
If you click the Preferences button in the non-modal data browser (the one you get from Data->Data Browser) and turn on the checkbox for Remember Position and Size, then the data browser you get from CreateBrowser prompt="message" will have the remembered size and position.
