Word Wrap Textbox
RGerkin
Function/S WordWrapTextBox(textBoxName,wrapWidth[,windowName]) String textBoxName Variable wrapWidth String windowName if(ParamIsDefault(windowName)) windowName=WinName(0,5) endif Variable layout_=(WinType(windowName)==3) if(!strlen(textBoxName)) String annotations=AnnotationList(windowName) Variable i,textboxes for(i=0;i<ItemsInList(annotations);i+=1) String info=AnnotationInfo(windowName,textBoxName,1) String type=StringByKey("TYPE",info) if(StringMatch(type,"Textbox")) // Apply word wrapping to textboxes is graphs and layouts. textboxName=StringFromList(i,annotations) if(layout_) // Layout String layout_info=LayoutInfo(windowName,textboxName) Variable selected=NumberByKey("SELECTED",layout_info) if(!selected) continue // Only apply word wrapping to selected textboxes in layouts. endif endif String result=WordWrapTextBox(textboxName,wrapWidth,windowName=windowName) textboxes+=1 endif endfor if(textboxes==0) return "" else return result endif endif Variable currentLineNum = 0 // determine the dimensions of the textbox where this text will be placed. info=AnnotationInfo(windowName,textBoxName,1) if(strlen(info)) String textStr=StringByKey("TEXT",info) String rect=StringByKey("RECT",info) Variable left,top,right,bottom sscanf rect,"%f,%f,%f,%f",left,top,right,bottom Variable textHeight=bottom-top else // Textbox doesn't exist. return "" endif // Protect double carriage returns and carriage returns followed by tabs. textStr=ReplaceString("\r\r",textStr,"<|r>") textStr=ReplaceString("\r\t",textStr,"<|t>") // Kill old carriage returns. textStr=ReplaceString("\r",textStr,"") // Bring back protected characters. textStr=ReplaceString("<|r>",textStr,"\r\r") textStr=ReplaceString("<|t>",textStr,"\r\t") Make /o/T/n=0 outputTextWave String returnTextStr="" Variable firstLineNum=0 // get the font information for the default font used in this panel if(layout_) DefaultGuiFont all else DefaultGuiFont/W=$(windowName) all endif String defaultFontName = S_name Variable defaultTextFontSize = V_value Variable defaultTextFontStyle = V_flag // now read information from title control to see if // a non-default font size, style, or name is being used Variable textFontSize=NaN, textFontStyle=NaN String fontName, escapedFontName sscanf textStr,"\Z%d",textfontSize if (numtype(textFontSize) != 0) // default font size is used textFontSize = defaultTextFontSize if (numtype(textFontSize) != 0) textFontSize = 12 endif endif sscanf textStr,"\f%d",textfontStyle if (numtype(textFontStyle) != 0) // default font style is used textFontStyle = defaultTextFontStyle if (numtype(textFontStyle) != 0) textFontStyle = 0 endif endif sscanf textStr,"\S'%[A-Za-z]'",fontName if (cmpstr(fontName, "") == 0) // no font name found fontName = defaultFontName if (cmpstr(fontName, "") == 0) // will be true if S_name above is "" fontName = GetDefaultFont(windowName) endif endif // Determine the height, in pixels, of a line of text Variable lineHeight = FontSizeHeight(fontName, textFontSize, textFontStyle) Variable maxNumLines = Inf//floor(textHeight / lineHeight) // search for spaces, check length of string up to that point + length of new text, and decide whether // to add the new word or add a line break Variable sourceStringPos = 0 Variable nextSpacePos, nextCRPos, nextBreakPos Variable currentTextWidth, newTextWidth Variable breakIsCR = 0 String nextWordString = "" String currentLineString = "" do nextSpacePos = strsearch(textStr, " ", sourceStringPos) nextSpacePos = nextSpacePos >= 0 ? nextSpacePos : inf // set to inf if space is not found nextCRPos = strsearch(textStr, "\r", sourceStringPos) nextCRPos = nextCRPos >= 0 ? nextCRPos : inf // set to inf if \r is not found if (nextCRPos >= 0 && nextCRPos < nextSpacePos) breakIsCR = 1 else breakIsCR = 0 endif nextBreakPos = min(nextSpacePos, nextCRPos) if (numtype(nextBreakPos) == 1) // nextBreakPos == inf means there are no more spaces or \r if (strlen(textStr) == sourceStringPos) // at the end of the string returnTextStr += currentLineString break else nextWordString = textStr[sourceStringPos, inf] sourceStringPos = strlen(textStr) endif else nextWordString = textStr[sourceStringPos, nextBreakPos] endif currentTextWidth = FontSizeStringWidth(fontName, textFontSize, textFontStyle, currentLineString) newTextWidth = FontSizeStringWidth(fontName, textFontSize, textFontStyle, nextWordString) if ((currentTextWidth + newTextWidth + 5) <= wrapWidth) // add this word // leave 5px padding currentLineString += nextWordString if (numtype(nextBreakPos) == 1) break elseif (breakIsCR) sourceStringPos = nextBreakPos + 1 returnTextStr += currentLineString Redimension/N=(currentLineNum + 1) outputTextWave outputTextWave[currentLineNum] = currentLineString currentLineString = "" currentLineNum += 1 else sourceStringPos = nextBreakPos + 1 endif else // add a new line and then add this word returnTextStr += currentLineString returnTextStr += "\r" Redimension/N=(currentLineNum + 1) outputTextWave outputTextWave[currentLineNum] = currentLineString + "\r" currentLineNum += 1 currentLineString = nextWordString if (numtype(nextBreakPos) == 1) break else sourceStringPos = nextBreakPos + 1 endif endif while(sourceStringPos < strlen(textStr) - 1) returnTextStr += currentLineString // add last part of string to return string Redimension/N=(currentLineNum + 1) outputTextWave outputTextWave[currentLineNum] = currentLineString + "\r" Variable n String finalOutputString = "" Variable numLinesToReturn = min(DimSize(outputTextWave, 0), maxNumLines + firstLineNum) For (n=firstLineNum; n<numLinesToReturn; n+=1) finalOutputString += outputTextWave[n] EndFor finalOutputString=RemoveEnding(finalOutputString,"\r") KillWaves /Z outputTextWave Textbox /W=$windowName /C/N=$textboxName finalOutputString return finalOutputString End
April 6, 2009 at 11:14 am - Permalink
