Combination of two algorithms
Hi
I try to compare several groups to a common control. I have been trying to add a customized algorithm mean squared error (see the image ) into Dunnett Test function but failed.
Can you give me an idea about combining these two algorithm togather?
Here is the mean squared error code:
Function WSFI(ctrlwave, treatwave, xl, xr)
    wave ctrlwave, treatwave  //control waves
    variable xl, xr   // (left and right bracket)
    duplicate/R=(xl, xr)/FREE bw, bdw
    duplicate/R=(xl, xr)/FREE tw, tdw
    MatrixOP/FREE MSE=Sum(magsqr(bdw - tdw))/numPoints(tdw)
    return MSE[0]
Here is the DunnettTest function which was written by my boss
Function pksDunnettFn(ctrlWave)
    String ctrlWave
    WAVE M_DunnettTestResults
    WAVE /T T_DunnettDescriptors
    //Prompt ctrlWave,"Select control wave:",popup,WaveList("*",";","")+";_none_"
    String wName, wList, waveLabel, nStars
    Variable j, resultNrows, pValue, qValue, nWaves, totalSamples
    // print ctrlWave
    // compile wave name list from top table: ctrl wave first element
    wList = ctrlWave + ";"
    j = 0
    totalSamples = numpnts($ctrlWave)   // cumulate total # of samples
    do
        wName = WaveName("", j, 1)
        wName = ReplaceString(".d", wName, "")  // strip '.d' from wave names sometimes
        if ( (cmpstr(wName ,"") != 0) && (cmpstr(wName ,ctrlWave) != 0) )   // append wave name if not null or ctrlWave name
            wList = wList + wName + ";"
            totalSamples += numpnts($wName) // cumulate total # of samples
        j += 1
    while (cmpstr(wName ,"") != 0 )
    nWaves = j-1
    //print nWaves
    print wList
    // do the Dunnett's
    // StatsDunnettTest /ALPH=0.05 /T=1 /WSTR=wList /TAIL=4  /SWN
    StatsDunnettTest /ALPH=0.05 /WSTR=wList /TAIL=4  /SWN
    resultNrows = DimSize(M_DunnettTestResults, 0 ) // # rows in result
    Make /T /O /N=(resultNrows+1, 5) pksDunnettResultTable
    pksDunnettResultTable[0][0] = "CONTROL"
    pksDunnettResultTable[0][1] = "TEST GRP"
    pksDunnettResultTable[0][3] = "CONTROL MEAN"
    pksDunnettResultTable[0][4] = "TEST GRP MEAN"
    pksDunnettResultTable[0][2] = "P VALUE *0.05   **0.01"
    for (j=0; j<resultNrows; j+=1)
        // waveLabel = GetDimLabel(M_DunnettTestResults, 0, j )
        // next test wave
        // wName = StringFromList(j+1, wList)
        waveLabel = T_DunnettDescriptors[j]
        wName = StringFromList(1, ReplaceString(" vs ", waveLabel,";"))
        pValue = M_DunnettTestResults[j][5]
        if (pValue >= 0.05)
            nStars = ""
        elseif (pValue >= 0.01)
            nStars = "*"
            nStars = "**"
        if ( M_DunnettTestResults[j][4] == 0)
            // print ctrlWave + " vs " + wName + ":  mean " + ctrlWave + " (control) = " + num2str(mean($ctrlWave)) + ", mean " + wName + " = " + num2str(mean($wName)) + ". Means ARE different (P = " + num2str(pValue) + ")" + nStars
            // print ctrlWave + " vs " + wName + ":  mean " + ctrlWave + " (control) = " + num2str(mean($ctrlWave)) + ", mean " + wName + " = " + num2str(mean($wName)) + ". Means are NOT different (P = " + num2str(pValue) + ")"
        pksDunnettResultTable[j+1][0] = ctrlWave
        pksDunnettResultTable[j+1][3] = num2str(mean($ctrlWave))
        pksDunnettResultTable[j+1][1] = wName
        pksDunnettResultTable[j+1][4] = num2str(mean($wName))
        pksDunnettResultTable[j+1][2] = num2str(pValue) + " " + nStars
    print "* = significant at 5% level; ** = significant at 1% level"
    Edit /K=1 /W=(400, 70, 400+600, 300)pksDunnettResultTable as "Dunnett Result Table"
    ModifyTable /Z  width[1]=140, width[2]=140, width[3]=140, showParts=16+32+64
end function
I am not sure that I understand your goal here but here is the first cut. Look for comments that mark the 6 changes I propose and make sure to fill the xl and xr values.
function pksDunnettFn(ctrlWave)
    String ctrlWave
    // print ctrlWave
    j = 0
    do
        j += 1
    nWaves = j-1
    //print nWaves
    print wList
    // do the Dunnett's
    Variable xl=0,xr=1                                          // @@change 0 Replace 0 and 1!!!
    Make /T /O /N=(resultNrows+1, 6) pksDunnettResultTable  // @@change 1
    pksDunnettResultTable[0][5] = "MSE"                     // @@change 2
    Wave cw=$ctrlWave                                           // @@change 3
        // next test wave
        Wave ww=$wName                                      // @@change 4
        if (pValue >= 0.05)
            nStars = ""
            nStars = "*"
            nStars = "**"
        pksDunnettResultTable[j+1][5] = WSFI(cw, ww, xl, xr)        // @@change 5
Hi IGOR,
I am sorry that I did not clarify the goal. Yet you generously gave the best guesses for the goal.
I tried to calculate the mean square error within a range of waves used for Dunnett's test.
I have two groups for Dunnett's test
group 1- control
group 2- different treatments. eg. 5 different waves from 5 different treatments. group2a-2e
I can easily perform Dunnett's test, but I want to add mean square error into it.
At the end, I will have such data of comparison:
group1- group2a = Dunnett's score + mean square error
group1- group2b =Dunnett's score + mean square error
group1- group2c =Dunnett's score + mean square error
group1- group2d =Dunnett's score + mean square error
group1- group2e =Dunnett's score + mean square error
The mean square error which was written here ( the help from IGOR team previously)
    duplicate/R=(xl, xr)/FREE ctrlwave, bdw
    duplicate/R=(xl, xr)/FREE treatwave, tdw
    return MSE[0]
xl and xr are the bracket to set the range of wave.
supposedly, ctrlwave is the ctrlwave shares with Dunnett's test; treatwave is the group of 2a-2e.
I tried your suggestion, but failed to compile it with the message saying:
Got "WSFI" instead of string variable or string function name.
Error in Stats:pksDunnettFn
pksDunnettResultTable[j+1][5] = WSFI (cw,ww,xl,xr)
Any clues?
Thank you very much!!
Any clues?
change
to
pksDunnettResultTable[j+1][5] = num2str( WSFI(cw, ww, xl, xr) )
The former line attempts to assign a numeric value to a text wave. The latter converts the numeric value to a string before doing the assignment.
Hi Jtigor,
Thank you for the input. The error is gone.
I have received another error after running the function.
I got :
Function Execution Error
While executing Make, the following error occurred:
The number of points in wave must be between 0 and 2147 million.
and the table show up with empty value.
....Sot sure where to solve it.
Thank you in advance.
Use the Igor debugger. In any Procedure window, right-click and select Enable Debugger. Then right-click again and select Debug on Error. I would also right-click again and select NVAR, SVAR, Wave Checking, but you don't need that to solve the immediate problem.
Read about the debugger:
DisplayHelpTopic "The Debugger"
viralvector wrote:
Hi Jtigor,
I got :
The only statement that I can see involving the Make operation is this one
Either use the debugger as John suggests or a print statement to see what value resultNrows is taking on.
The debugger is a very useful tool to have. You should follow John's advice.
