Otherwise, if the place you want to use this has textbox formatting available, then a crude way of achieving this is the following text:
\[0v\[1\X0\S_\M\X1 more text
To understand this, I will break this into its components:
\[0 - store x-position in variable 0
v - the velocity symbol
\[1 - store current x position in variable 1
\X0 - recall x position from variable 0
\S - superscript
_ - underscore - this is now a bar above the letter v
\M - normal text (i.e. undo superscript)
\X1 - recall x position from variable 1
more text - you can continue with text from here as normal.
\S - superscript
Hope this helps,
Kurt
April 29, 2014 at 07:47 am - Permalink
