How to cite the path of a text data file in Macintosh computer with Flash Storage
pingerhitachi
When I tried to load a general data text file in program procedure as follows
loadwave /G/D/A=wave "private:Users:pingguangxu:Documents:IMATERIAdevelop:BSML.txt"
or
loadwave /G/D/A=wave "Macintosh hd:Users:pingguangxu:Documents:iMATERIAdevelop:BSML.txt"
the same response "the specified volume is not mounted" suggests that I used a wrong path.
however, when I use the terminal command, the path of BSML.txt file is as follows
/Users/pingguangxu/Documents/iMATERIAdevelop
About how to cite my file in a program, could you please give me some suggestion?
Or use Misc->New Path to create an Igor symbolic path and look at the path generated by the dialog.
To learn about Igor symbolic paths, execute:
April 8, 2014 at 06:12 am - Permalink
I have cleared this problem according to your suggestion.
April 22, 2014 at 07:11 pm - Permalink
