Subtracting baseline and peak integration
john_crow
I have some data that contains a non-linear background and a peak. How would I go about removing this background curve from the data so that I could integrate the area under the peak? Ive tried using TN020 but I can't seem to make much sense of it.
I've attached a table of the type of data I have. The file contains three columns, the first is the X axis range, and the next two are series of data that each have a unique background and peak.
Any help would be greatly appreciated!
http://www.igorexchange.com/project/Baselines
http://www.igorexchange.com/project/BaselineSpline
Otherwise, does your background have a known analytical form?
March 28, 2014 at 03:43 pm - Permalink
Your x wave (wave0) is linear, so you should convert your two Y waves to waveforms by applying X scaling.
If none of those words makes sense, please read this Help topic:
DisplayHelpTopic "Waves - The Key Igor Concept"
Your X wave is a little ragged (the increments vary a little), but I suspect you could use an Igor command like:
Setscale/I x, 600,800,"", wave1, wave2
to do the job.
March 28, 2014 at 07:48 pm - Permalink
