    Support of spectral image with 32 channels
I am curious whether IGOR supports spectral image analysis?
For example, a spectral image (lambda with 32 channels + XYZ + Time-lapse), I would like to perform linear unmixing for my spectral images in IGOR.
I then use a bunch of user defined functions often based around MatrixOP to access those spectra or just ranges of energies. I am pretty sure you can do what you want but you probably need to set it up yourself.
March 12, 2014 at 11:08 pm - Permalink
