Dynamical correlation between two graphics possible ?
Djebulon
I'm an Igor newbie and I want to duplicate a function of another program (developed in C) in my data analyzing in Igor.
Initialy I have a 256x256 .tiff image.
With simples equations I extract in Igor from this image 2 maps :
1 map of Itensity and
1 map of Brightness.
Each of them are 256x256 waves (see attached images) and are displayed in the main window.
I vectorized the maps information (instead of 2D[256][256] waves I create 1D[65536] waves)
I plot the Brightness vs Intensity for the vectorized maps and I displayed it in the same window.
I want to know if there is a possibility to obtain dynamicaly a visual correlation between a region of the "VerSus graph" and the corresponding pixels in the images of the maps.
The square representation is the ideal display I would want to get but it's not restrictive.
As I don't really know how to ask to Igor to re-lauch a "function" (/proc/macro) each time the mouse is acting in the graphic, the only thing I managed to program is a non-dynamical defininition of a region (with 4 setvariable) and with a "button" to lauch a function.
The function just checks the value of the brightness and of the intensity and creates a mask to change the pixels in red.
It's very time consuming.
Does anyone know if it's possible to ask to Igor to maintain the execution of the program in a "waiting" state in order to lauch a loop when interacting with a graphic ?
Thank you very much
The attached files are :
01 - The Intensity map
02 - The Brightness map
03 - The Brightness versus Intensity graphic extract from the 2 vectorised maps
04 - The display of the window with the 3 elements.
05 - Example number one of the correleation between a defined square of pixels of the Versus Graph and the corresponding pixels in the 2 maps
06 - Same example but with the square moved to the right.
07 - Igor project with the differents waves.
![01 - Intensity map.jpg](/sites/default/files/styles/content_body/public/images-imported/01%20-%20Intensity%20map.thumbnail.jpg?itok=EXRuwJmn)
- Redimension both maps from 2D into 1D
- Create a bivariate Histogram (see e.g. http://www.igorexchange.com/node/4651). Here my approach is that the bin size for the histogram is always 1 count (of intensity)
- Plot histogram as NewImage
- Then I use a region of interest (ROI) tool (under image analysis) to select an area on the histogram (see picture), which means creating a mask with 1 for "within the ROI" and 0 for outside
- After multiplication of the mask with the histogram I am left with pairs, say X and Y, of intensities of two elements
- Now the task is to find the pixels in the initial 2D images where X AND Y counts occur. This is simplified by using a Cantor pairing function to generate one unique integer out of two: http://en.wikipedia.org/wiki/Pairing_function
- now the XY pairs from the histogram and the two 2D maps are "cantored"
- then I need to find the correct Cantor values. For this I got input here: http://www.igorexchange.com/node/5447 , although my final version differs from what I wrote back there
All this is implemented in a graphical user interface (see image). The visualisation of the pixels is executed when clicking the "Get Pixels" button. Initially I wanted this automatically to run once the polygon from the ROI action closes, but I didn't find a way to do that.
Hope this gives you an idea but maybe there are better ways.
February 4, 2014 at 05:26 am - Permalink
Thank you for your answer.
If I understand well, you are suggesting to transform my "versus graphic" into an image in order to "Cantor pairing" the pixels.
My little problem with this option is that the rest of my program is interacting with the data inside the "versus graphic" and I want to keep it dynamically updated when changing parameters (Threshold of intensity and brightness for example).
* The correlation between the pixels of the "maps images" and the pixels of my "versus graphic" is obvious in my case :
each pixel of the map has a [i][j] coordinate (256x256).
In the "Versus graphic" made from the vectorized maps each point has an index between 0 and 65536.
I can extract the coordinate in [i][j] of each point of my "versus graphic" doing this : [i] = floor (index/256) and [j] = mod(index, 256)
* If I manage to draw a rectangle in this graphic, when selecting several point with this rectangle, I will obtain their coordinate in the maps directly with their index.
But I don't know how to draw a rectangle in my "versus graphic" (and I don't know if it's possible) without changing it into image (to keep the live update I need). Moreover, I don't know how to identify the points selected in the graphic (like the masqueetomask tool which creates a mask with 0 and 1).
I'll keep going to find a solution and I'll try to adapt yours but, even if your work seems very close to mine, I'm not sure it will fit with my needs.
Thank you again :)
February 5, 2014 at 01:34 am - Permalink
Looking closer at your data it is probably not possible to easily adapt my approach to your data. The pairing works for integers, which in my case typically are between 0 and a few hundred (max) for both input images. The main advantage is to speed up the look-up process to find the desired pixel coordinates. The above approach is virtually instant for images up to 512*384 pixels (larger not tested). For me it is important to have the density plots because I'm looking for distinct populations with high pixel abundances of count pairs.
This you can do using
FindPointsInPoly
andGraphWaveDraw
, which can be used to achieve pretty much the same as the ROI mask does on the 2D histogram.February 5, 2014 at 02:04 am - Permalink
I will try to see if I can adapt them to my problem but they seem promissing.
February 5, 2014 at 08:21 am - Permalink
The attached experiment shows an example. Execute
PixFromHistogram(Al, Si, M_Hist, M_ROIMask)
to get a mask of the pixels of interest.
You can play with different ROI's on the histogram using "Analysis -> Packages -> Image Processing" then "Image -> ROI". Make sure you uncheck "Zero ROI pixels" in the panel.
February 6, 2014 at 03:56 am - Permalink
Okay it seems that I have a lot of work to adapt it to my issue :S
But with
FindPointsInPoly
andGraphWaveDraw
and with your code, I will find a way to do it.I'll let you know when it will be done ...
Thank you again !
February 6, 2014 at 06:13 am - Permalink
Have you looked into using the Marquee for this?
February 6, 2014 at 06:30 am - Permalink
With the marquee option, you can have a rectangle but you just identify the coordinates once. (right clicking and doing marquee2mask)
When it's done, I didn't find a way to shift the rectangle and to act dynamically on the image displaying the identified pixels (when dragging the rectangle)
February 10, 2014 at 07:03 am - Permalink
I just tried this on my code:
This works kind of dynamically after dragging the ROI and release of the mouse button, not while the ROI is moving. But there are side effects because this action may be triggered by other events than moving the ROI.
February 11, 2014 at 02:30 am - Permalink
I managed to get almost what I wanted using a little trick and only buttons.
I don't drag the rectangle but I shift it.
Thank you Chrlie for these 2 functions :
FindPointsInPoly
andGraphWaveDraw
And four buttons and associated functions are created : Left, Right, Up and Down with 2 setvariable : x-increment and y-increment.
If you think you will be intersted in this non-complete method, I can simplify my procedure file and post a saved experiment here with an exemple.
February 14, 2014 at 06:32 am - Permalink
