Modify the waves appearances
1. Is there an easy way to display tiff images in greyscale beside averaging the image manually in a second matrix?
2. Is it possible to select the point boundaries of a wave to display, e.g. display only the values between point 100 and 200?
3. Can I change the plot density of a trace, e.g. display only every second or 5th point?
I could write for all of these some functions which would create a duplicate wave with the right properties, but the points above are only for display purposes and I don't want to create every time a duplicate wave If I changed some parameters. Thanks in advance!
MatrixOP/O gray=rgbWave[][][0]
2. Use SetAxis.
3. Check out ModifyGraph with mask keyword.
November 6, 2013 at 05:24 pm - Permalink
DisplayHelpTopic "Subrange Display Syntax"
(Beat you to it John:)
November 6, 2013 at 05:34 pm - Permalink
Thank you, I was using this before but totally forgot about it after some years.
November 7, 2013 at 08:37 am - Permalink
It's not really fair for you to do this while I'm off playing squash matches with 12-year-olds!
November 7, 2013 at 09:23 am - Permalink
