Catching enter key in ListBox
thomas_braun
I have ListBox which does something on doubleclick. Now I would like to be able to complete control the ListBox using the keyboard.
But I'm not able to check if the user pressed the enter key on an entry.
Minimal example:
Function doStuff()
Make/T/O/N=5 list
list = "text " + num2str(p)
NewPanel/K=1
ListBox list1, proc=listBoxProc,listWave=list, size={150,150}, mode=1
Function listBoxProc(lba) : ListBoxControl
STRUCT WMListboxAction &lba
Variable row = lba.row
Variable col = lba.col
WAVE/T/Z listWave = lba.listWave
WAVE/Z selWave = lba.selWave
switch( lba.eventCode )
break
case 1: // mouse down
break
case 3: // double click
if(!WaveExists(listWave) || row >= DimSize(listWave,0))
printf "row: %d\r", row
break
case 12: // keystroke
if(!WaveExists(listWave))
printf "pressed key: %d\r", row
break
case 13: // checkbox clicked (Igor 6.2 or later)
break
endswitch
Make/T/O/N=5 list
NewPanel/K=1
break
break
break
break
break
endswitch
Currently I use the "." (ASCII 46) as workaround but that is kind of uninutitive.
Any ideas?
October 14, 2013 at 04:25 pm - Permalink
thats definitly a step in the right direction. Although I never wanted to edit the cell contents.
Now I have:
DoWindow/K Panel0
Make/T/O/N=(5,1) list
Make/U/B/O/N=(5,1,2) sel
sel[][0] = 0x02
// override edit color
Make/O/W/U/N=(5,3) myColors = 65535
SetDimLabel 2, 1, backColors, sel
NewPanel/K=1
ListBox list1, proc=listBoxProc,listWave=list, size={150,150}, mode=1, selWave=sel, colorWave=myColors
break
break
break
case 6: // begin edit
print "begin edit aka pressed enter the first time"
// forcefully end cell editing
ListBox list1,disable=1
ListBox list1,disable=0
// how to get the focus onto the ListBox back ?
break
case 7: // end edit
print "end edit aka pressed enter again after begin edit"
break
case 6: // keystroke
break
break
endswitch
With a formerly here posted hack to finish cell editing.
But how can now the listbox get the keyboard focus back?
October 15, 2013 at 02:45 am - Permalink
A check of the sourcecode indicates that you will never get the return key while the listbox has keyboard focus. Someday maybe we can address this issue- it's actually one that I have faced myself.
A window hook function will get the keystroke, but only when the listbox does not have keyboard focus.
October 15, 2013 at 09:44 am - Permalink
so I'll stick to "." for now.
October 16, 2013 at 12:52 am - Permalink
